Slid out "out" permanently?
chast
Hi all--our '99 Bounder has one LR/DR slide. Unit is permanently parked on our lot in Florida. We live in it for eight months a year and are away from it the rest of the time. Is there any reason that I can't or shouldn't leave the slide out all the time? Thanks as usual for any and all advice.
chartrue2@aol.com
10 REPLIES 10
2gypsies1
I can't imagine why you would want to leave it out when gone. It's so easy to bring in.
Full-Timed for 16 Years
.... Back in S&B Again
crasster
Surround it with a built structure/roof. If you want to use the windows get a carport on top that "lips" out down, like a roof eve, but does not cover the windows. This is for added protection.
Put cinder blocks under the RV in multiple spots (frame) and level it out. I would get it off the tires for sure.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
Dale_Traveling
For me slides and awnings move together. Awning in the slide is in.
A slide will seal much better in than out. It's made to be tight against 60MPH wind blow rain when retracted. Think going down the road with this one. Plus one good storm and the topper is toast. Close it up when leaving for more than a day.
2006 Hurricane 31D built on a 2006 Ford F53
cdl2
Why would you want to leave it out?
I say pull it in when you head north.
LadyRVer
Tropical Storm winds or hurricane winds .... my slide comes IN.
bfast54
If it were me if I were gone for even a week --I put my slides in
yeah if you're gone for a month 2 months 3 months 6 months definitely bring the slides in --that way you keep the mechanism operating and there's less overall roof expose-- if you follow
2000 Ford SuperDuty F-350 Powerstroke,Dually.C.C.,.The Tow Monster
2005 Open Road 357RLDS
Prodigy Brake Controller:B
Honda EU3000is Generator
Raytek ,,Garmin 7735/GPS
Doran Mfg-RV360-TPMS
B&W/Companion
Rally's attended so far-21
My Blog
Good Sam Member
gbopp
ScottG wrote:
Being a MH, I would drive it occasionally or risk paralysis.
x2. I wouldn't leave the slides out while gone for several months. It just seems like you're leaving more of the RV exposed to the elements and increasing the chance of a leak
ScottG
John_Joey
If that was your intent to be permanent, I would brace the frame so it would not sink if tires lost air or jacks lost pressure, then I would brace the slide also.
In essence you would be putting a foundation under the whole living area, even if it was simply screw up jack stands.
Thereโ€™s no fool, like an old fool.
rgatijnet1
Any chance of building a carport like structure over the entire RV to protect the roof from the inevitable deterioration? I've seen this done on many hunting trailers. Nothing fancy but enough to protect the RV roof from the elements.
