Small Class C on Truck Chassis?
shelbyfv
Do these exist? Current models on truck rather than van chassis? The smaller the better as long as it has a toilet and holding tanks.;)Thanks!
30 REPLIES 30
IAMICHABOD
The one that Snowman900 linked is a Former Rental that was discontinued in 2005. They still may be found,I think I know where there is one.
Here is a LINK to an old post that may help you out.
YouTube Majestic 23P
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
shelbyfv
^^^That's pretty close to what I was thinking of. And wow, the Tiger looks great! Seems to be priced about half again what I was hoping for but who knows? Thanks, guys.
Snowman9000
Currently RV-less but not done yet.
Snowman9000
Cruise America had a Majestic brand unit exactly what you are looking for. They no longer use them, but they are out there somewhere. I can’t remember the model number.
IAMICHABOD
Maybe a Tiger RV
shelbyfv
^^^That's the idea but probably 10' longer than I'd like!
enblethen
Dynamax calls theirs a class C, but I would call it a mini- super C!
Dynamax Class C
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
DrewE
gbopp wrote:
What's the difference between a truck chassis and a van chassis?
As was said, primarily it's the relationship of the engine, seating, and front axle relative to each other. On a truck chassis, the engine is in front of the dashboard and the seats are relatively low in the frame (and the floor often isn't flat around them, thanks to the driveshaft etc. running under them). On a van chassis, the engine is partly underneath the dashboard and the seats are mounted higher up, so the floor is flat and can be continued back along the chassis flat and level. Most class C motorhomes do still have a step up from the cab area, though, to provide additional underfloor space for tanks and storage space, so the floor isn't entirely flat from the cab back.
In terms of engines, frames, axles, transmissions, suspension systems, and that sort of thing, they can be approximately comparable, though rarely identical. Current Ford truck chassis are more advanced than their van chassis in many regards, particularly with the front axle design which is rather long in the tooth for the van chassis. The trucks also tend to have newer engines and transmissions and such like.
You can build a truck on a van chassis easily; smallish box trucks based on the E series chassis, for instance, are not all that rare.
tarnold
Tiger or $$earthroamer$$
shelbyfv
I see them on E450, wondering if F450 exists. Thinking maybe better handling, engine placement, 4X4 etc. I'm thinking very small, closer to B size.
Mfan
Dynamax, darn spell check
Mfan
Engine placement
gbopp
Mfan
Possibly from duramax, who makes the super c on freightliner
Mfan
Yes they do. I've seen several lately,but they have been leaving Elkhart area. Looks like on a f450 frame
