Small Class C
Sailscalls
I've wanted a truck camper for sometime to be able to get to remote fishing areas. Lately I've thinking a small class C towing a Jeep Wrangler might be a better setup for me. I can find a spot to camp then explorer fishing spots with the jeep. So I have a few questions I'd like input on.
1) Is there much difference in driving a 22' through 28' and is the mpg about the same?
2) Is mpg on a B+ any better than a Class C?
3) Can you get locking differential on a E-350 or E-450 or does Chevrolet van chassis have it available.
4) I've seen a lot of 22-25' on E-450 is a E-350 sufficient or is the 450 much better?
5) I googled Ford E van chassis but didn't find much information. Can someone recommend a website for Ford and Chevrolet van cut away chassisc.
6) Do you need power leveling system on a "C". I had a class A years ago that had them and they were great.
7) I've read on here that some "C" drives well and some terrible? Do certain camper manufactures like Holiday Rambler, Winnebago handle better than some lower price models? I assumed manufactures wouldn't do anything to the chassis just build the camper. If so, why do some drive well and others not so good?
๐Ÿ˜Ž I'm considering Holiday Rambler, Winnebago, Coachmen, Four Winds are there other brands I need to consider ? Are there much difference in the build and quality of the mention brands?
Thanks for your help
15 REPLIES 15
pnichols
The E450 chassis does more than carry more or tow more.
On small Class C motorhomes that don't need the E450 for the above reasons, an E450 gives you bigger brakes for more time between brake jobs, more transmission cooling for less heat load on the engine and longer transmission life, a 4.5 inch wider rear dually stance for better lateral stability offroad and in high side winds, pump boosted power steering instead of vacuum boosted power steering (at least for our model year of the E450), thicker steel in the chassis frame for less frame torsional twisting transfer into the coach box, and lower differential gearing when pulling up long grades for less heat load on the V10 in hot weather.
We considered the long term benefits of the E450 over the E350 as well worth the (relatively) few extra dollars we had to pay for the option when we bought our small Class C. Since we go offroad in the desert with our Class C, we generally feel more secure with the additional chassis ruggedness under us.
2005 E450 Itasca 24V Class C
EMD360
It depends on your budget. It is MUCH easier to find an older short E-350 than any of the others. And they are cheaper. An E-450 may carry more weight, but we stock ours full and are still under full weight. Have not had issues with handling.
We are fine with climbing up into bed in our 22 ft rig. It is not that far when we step on a stool on the dinette bench after the cushion is removed.
We love the short length and have taken it on many an AZ dirt road. We use "training wheels" to keep from losing anything underneath although we lost one set of those wheels and the steps on a particularly rocky unpaved road. We do the repairs and go back out again.
We typically go from 3 to 10 miles off the paved roads to find seclusion and have never tried to tow. We fit in some restaurant and smaller parking spaces by backing in and overhanging a spot that is over grass, and in big parking lots it is OK to take two.
But there are folks who tow jeeps and love the extra ability to go on 4wd roads. Could never get as far off road with the RV though if we towed. Maybe taking a dirt bike on a rear mount would offer the flexibility you want and still be short enough to get out of established spots.
I like to take photos of how isolated we are when we camp. This one is from northern AZ, not far from the northern side of the Grand Canyon.
Have fun shopping!
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
Bordercollie
If you are concerned at all about sleeping comfort or have arthritis problems, you will want a rear bedroom with RV queen sized bed. Sleeping in the overhead or on folding sofas or converting dinettes is no fun for most people. If so, you are limited to rigs no less than 26-27 feet long. Not much good for typical off road or back road travel. A Truck camper may be best for fishing, etc., in back country by one person.
Snowman9000
Based on reports here, I use these assumptions on MPG:
Ford B+ 9-10
Ford C 7-8
Chevy B+ 10-11
Chevy C 8-9
Obviously length and weight matter but not as much as you might think.
People say driving them is all the same regardless of length.
Very few of them have levelers.
People seem to feel the Chevy handles better than the Ford, although there are fixes for the Ford ranging from alignment (set caster to maximum positive) to $$$aftermarket parts.
Currently RV-less but not done yet.
winnietrey
I don't know about the paved road thing Tatest. I have a 24ft 01, Coachmen, with a slide.
Now I admittedly am not the brightest crayon in the box, But I have driven at least a 3 or 4 thousand miles, of gravel roads with it. Some good, some very rough. And probably a thousand miles or so on logging road stuff.
Probably hard on it I agree. But my rule of thumb is if I can get a passenger car up it, I will take the RV.
My Rv being short, has little rear overhang, And better ground clearence than any passanger car
That said I agree, it is not a truck, but I think he can probably gets what he suggests, towing a jeep into some pretty remote boondocking spots, up some pretty rough roads and go forth in the jeep from there
That's been my experience at least. Now the truth is, of course that way of thinking, has well, got me into a situation or two, Thats lets just say, the DW was not real pleased about. But never have been stuck yet. Knock on wood!!!!!! Been yelled at a few times though. LOL
tatest
1) Not in my experience, factors other than length matter more, and MPG is determined more by frontal area and how you drive.
2) Some B+ designs are lower and narrower than most C's, and some cap designs help slightly with drag coefficient, so on the whole, B+ is better MPG, but that depends also on which specific model, whether C or B+.
3) I know you can get either a locker or limited slip for the axle used on the E-350, Ford offers it as an option, and limited slip shows up on some emergency vehicles, but RV manufacturers don't buy the option. If what you really want is a locker (drag racing or rock climbing?) you must buy aftermarket. Don't know about Chevy, whether using Dana or GM on the cutaways.
4) Whether or not E-350 is sufficient depends more on weight than length. A 28 with no slides could be a lot lighter than a 22 with two slideouts. E-350 offers opportunity to get a V-8 that does better with MPG, which seems to be an issue for you, or if you find the right one used, a Powerstroke.
5) Your local Ford TRUCK dealer should have an excellent brochure on the E-series. I've been collecting them since 2005 and find them more useful than Ford's website, which doesn't have all the information in one place, you have to make multiple "build" passes to draw out answers. I've not found a comparable brochure from Chevy, but my local dealer may not really be a truck dealer.
6) I don't think you need a power leveling system on anything, but the larger the RV the more work it can be to level, and yes the systems are nice if your leveling problem is in the range of operation. C's do not usually have power leveling, the cost works against sales in the price sensitive C market. If you are thinking off road or back road, power leveling tends to add to a motorhome's already difficult clearance problems.
7) Whether a C (or A, or truck camper, or van) handles well or poorly depends less on manufacturer, more on whether the house is too big for the chassis, and the distribution of mass and surface area relative to pivot points. It also depends on who is driving it, expectations, experience, and driving skills. I know that driving a 22 foot (overall) box truck on Express 3500, E-350, E-450 cab-chassis, especially lightly loaded (about 8000 GVW), feels like a sports car compared to my 12,500 pound 30-foot motorhome on the same chassis. But what a 22 footer filled to 12,000 to 14,000 pound capacity feels like, I don't know, because I haven't rented a box truck to carry a heavy load, only lightweight bulky loads.
๐Ÿ˜Ž Mass producers Winnebago, Thor, Coachmen, Forest River, Fleetwood, Jayco, use similar construction techniques, a box constructed of laminated panels stiffened by aluminum frame members. There are differences on how the box is assembled, Winnebago using interlocking aluminum members, most others using point fasteners. Forest River and Winnebago have been skinning the roof with fiberglass sheeting, others are still using lighter synthetic fabrics. If you inspect different mass production RVs closely, you will find significant differences in fit and finish, materials, type and number of fasteners, quality of other hardware items.
Holiday Rambler built motorhomes differently, with aluminum framing built up from floor, then skinned and filled. This was when Holiday Rambler was still building the C's and A gassers for the Monaco brands.
That changed to laminated panel box construction, like everybody else, when the H-R (and other Monaco) brand was put on models built at the recently acquired R-Vision plant.
I inspected Thor, Coachmen, Jayco, Fleetwood, Forest River examples closely, and visited four of the factories, which made me go with Winnebago. But they are not the best, as you can get better construction using either modern or traditional construction methods, from some small RV builders, if you want to pay the price. For construction quality, have LazyDaze build you one.
There is no taking most C's very far from very good paved roads. They are too long, too much wheelbase, too much rear overhang, too little ground clearance to deal with even minor bumps, dips, crowns and ruts. A big part of the house is built in a "basement" hanging down over the sides of an already too low frame.
Short C's do better than long ones, but even short conventional C's will have nearly half the house behind the rear axle to get weight distribution right at maximum weight.
There are important exceptions, like Tiger, the old Xplorer line, and Host Industries' expedition vehicles. You will find these built higher, on conventional cab chassis with higher frames, and with less of the house hanging low under the floor and the frame rails.
I would rather have a truck camper to get to remote fishing areas. It would depend on how remote, are you having to go 2-3 miles from a convenient RV campground, or is your fishing site going to take you 20-50 miles from the nearest facility that can handle the motorhome?
Tom Test
Itasca Spirit 29B
IAMICHABOD
Here is a website for the Chevy Express Cut away that may be helpful.
Chevy Cutaway
As stated before the Fords seem to be Plagued with bad handling that takes $$$ to fix. Like HERE
While the RV's built on the Chevy Chassis do not seem to suffer the same fate.
A discussion about that can be seen HERE Among other things such as fuel mileage and cockpit room.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
kriscott
I tow my Jeep with my 25 foot MH and it works out great. I have the E450 and it tows the Jeep with ease. And when I get to my destination, my Jeep takes my ANYWHERE I need to go. Especially off the beaten path to find secluded fishing spots!
mrnoyb
I've owned a Thor Chateau 22E for 3 months and 1800 miles. I'm happy so far. It's only 24 ft bumper to bumper but includes everything we need for comfortable travel.
An E-450 chassis would only increase the GVWR. Generally not necessary on shorter lengths.
The MPG is horrible so if fuel economy is an issue, refrain from purchasing any RV.
I keep reading about Ford E-Series Cutaway Handling issues but can't say I've noticed anything unusual.
Leveling systems are not necessary on shorter lengths.
The length of a unit does impact handling.
Traction control is available but you would almost certainly need to special order to get it.
http://www.ford.com/commercial-trucks/eseries-cutaway/features/
mikebreeze
I have a small class C and have been very happy with it. Sleeps 2-4, about 10 MPG. I believe Thor makes a 22 foot Chateau model with a Chevy Van front.
2006 Four Winds Majestic 23A
Harvard
IMO, another possible cause of handling complaints of the E350/E450 has to do with not having enough +caster. A caster of +3.5 degrees may be good for a cube van used in city traffic but +5.5 degrees is better for driving an RV on the highway. IMO. Here is a link to my experience.
E450 Handling
Handbasket
The handling complaints are almost entirely about the Ford E-series. A long rear overhang relative to wheelbase may aggravate this. The Chevy Express seems to drive well, but won't carry (or tow?) as much. The Chevy cab is more comfortable.
You'd probably have to special order positraction on most van-cutaway C's and wait for it to be built, with much less negotiating leverage. That, or get really lucky in finding it in a used C.
X2 on Tiger's comment. 7.5 years with mine, and still lovin' it. Can be had on any Big 3 1-ton pickup, with any driveline, cab trim, and cab size offered.
Jim, "I used up all my sick days, so I called in dead."
'06 Tiger CX 'C Minus' on a Silverado 2500HD 4x4, 8.1 & Allison (aka 'Loafer's Glory')
GENECOP
Power leveling is nice on a C but not required....you can level pretty easily with blocks...also if you are considering 4x4 power leveling is not a good idea, clearance underneath is more important..
GENECOP
B+ will probably get better mileage than a C.......check out Liesure Travel Vans.....Coach House and Lazy Daze. As Tiger said if you want to go off the beaten path Tiger or Earth Roamer.... Are what I would consider.....
