โMay-14-2015 07:01 PM
โMay-16-2015 05:50 PM
โMay-16-2015 11:34 AM
โMay-15-2015 11:08 PM
โMay-15-2015 07:17 PM
โMay-15-2015 05:20 PM
โMay-15-2015 05:12 PM
โMay-15-2015 04:37 PM
lj2654 wrote:
Anything above 65 is a death wish anyhow! Whether driving a MH with or without a toad, pulling a travel trailer, or hauling a 5th Wheel doesn't really matter.
Being in control is what matters. Vehicles stopping quickly on the Interstate,
construction areas(everywhere), drivers pulling into your lane from on ramp causing you to brake quickly, and off ramp speeds drastically dropping the last second.
โMay-15-2015 04:33 PM
Gamecock7483 wrote:
I have a Saturn ION and owners manual says the vehicle can be towed, but max of 65 miles per hour. Is this particular to the Saturn or is this common to other towed vehicles? Not that I plan to do a lot of driving over 65, but just curious. Thanks.
โMay-15-2015 02:42 PM
โMay-15-2015 08:44 AM
โMay-15-2015 07:58 AM
et2 wrote:
It's mechanical. If it were a safety issue all the manufacturs would state the same. It's about proper lubrication and heat. IMHO its how they disconnect from the engine and trans. If there is anything left spinning, not getting proper lubrication and cooling then there is a heat building up and friction on gears and bearings that aren't lubed as they should.
Why people wish to dispute the printed material provided by the manufactures regarding this is scary. I guess it's the same reason we hear some people drive 75 -80 mph or more knowing there is a speed rating on their tires. Sooner or later it'll catch up to you.
If you value your cars warranty then you'll follow the instruction manual provided to you. Or there are other choices in vehicles that would be a better selection.
โMay-15-2015 07:30 AM
โMay-15-2015 05:13 AM
โMay-15-2015 05:02 AM
