Mar-13-2016 06:52 AM
Mar-16-2016 11:28 AM
CaptainCal wrote:
99 Ford's use an electric speedometer. They can be reset by you to read accurate for tire size changes. Type in 99 e350 speedometer on {YOU TUBE}. It will give you instructions on how to. Get the value that your speedo is presently set at and start from there.
Mar-16-2016 06:37 AM
Mar-15-2016 07:38 PM
Matt_Colie wrote:
Nobody's speedo is right on, you have to look. Is the error constant or linear. Meaning is the error always 5 or is it half of what you see at 70 when you are at 35??
The constant error can be fix as above, more the pointer on the shaft. If it is linear, then call a Ford dealer. Manufactures often have different speedo pickup gears for this. When they build a transmission they don't know what the final drive will be and the driveline people don't know what tires will be on the assembled vehicle.
Matt
Mar-14-2016 08:15 AM
Mar-14-2016 06:19 AM
Mar-14-2016 06:12 AM
Mar-13-2016 06:33 PM
Mar-13-2016 02:12 PM
Cobra21 wrote:
If the tires are smaller than factory spec. it will read fast. Check if they
are the correct size?
Mar-13-2016 10:45 AM
Mar-13-2016 10:38 AM
Mar-13-2016 10:30 AM
Mar-13-2016 08:33 AM
Mar-13-2016 07:50 AM
Bud
USAF Retired
Pace Arrow
Mar-13-2016 07:33 AM
