JimM68 wrote:
I want to put lights under my steps (Kwikee) before I put them back together. Originally, there is this little hockey puck thing that is way up under the RV and basically does nothing but cast a glow on this little circle of dirt.
I'm thinking about truck clearance type lights, I can use counter suck screws to attach them before I put on the new antiskid.
Wondering what to wire them to?
Not sure when the existing light is on, seems to be all the time? I'll hafta study on it. I'd love to wire it to my motion detector starlight porch light, but have yet to figure out how to fish the wire down thru the wall? Tips on this would be welcome too.
What have you done to provide proper step lighting?
Hey Jim,
Well, you're in luck. I just finished one of my little projects. Originally I, like you, like everyone else with a Kwikee step light, had the little "puck" orange light. That thing is junk. So, one day while at a auto parts store, I came upon some nice little LEDs that, I knew were going to be better than what was under there. So, I bought them and, removed the junk-puck and, installed the two LEDs, one on each side under there.
That turned out to be seriously brighter than what was there. So, I lived with that for a while. Then, I got an even better idea. I purchased some LED STRIP lights off ebay and started goofing around with them just to see the effects on certain applications. I was having a ball with those. And, talk about a cheap project. It just about don't get any cheaper than this.
The first part of this project was simple. I cut a section of those strip lights and, stuck it to the bottom side of the body, just above the first/highest step. And, I tied it into the wires that trigger the new LEDs that I installed a while ago. Now, that made a serious difference in illuminating the steps. Whereas, the LEDs that I had installed really only illuminated the underside of the step area, to the rear of the steps. Good but, not great.
While that did a nice job of illumination of the top step, I wanted still more. So, I purchased some other, MUCH BRIGHTER LED light strip and, started goofing around with it.
What I did with a section of that was, glued it to the front/underside lip of the bottom step. Then, I glued the rest of that strip, to a rail, under the compartment doors, on the passenger side of the coach. That section is 15' long. I then wired in a separate switch to control both the long section under the compartments and the new little one, on the bottom side of the step.
WOW!!!! You should see the underside of the coach and, the front step now!! It's so COOL! I now have several choices for illumination on that side of the coach, in the evening hours. I have an LED strip just under the awning mounting point on the upper part of the body which, is seriously bright or, dimmable if you really want "mood" lighting. Or, I have the "Under body strip" and under front step light which, is really a nice effect. Or, I've got an LED porch light which also illuminates the door handle. Or, if I leave the screen door open, it illuminates the orange LEDs under the step and, the LED strip under the body lip, just above the top step.
This stuff was all fun to do and, just about "0" technical issues. I've also done some recent LED under isle lights in the coach too which really turned out well. Below are some photos of how they look. There's one that shows the much brighter LED strip vs the less bright LED strip, while sitting on the floor of the garage. And, one that shows the effects of the under-body lights with the garage lights on and, one with them off. And, you'll figure out the rest.
Oh, and I also goofed around with some under-bed-rail lights of my truck too. That was a kick to get that job done.
Scott
Scott and Karla SDFD RETIRED2004 Itasca Horizon, 36GD Slate Blue 330 CAT
2008 Caliente Red LVL II GL 1800 Goldwing KI60ND
