Strange "Buzzer"
Pass42
If I depress the service brakes, parking brake engaged, and put the bus in either D or R, a "buzzer" in the dashboard sounds... on/off, not constant........
If I depress the service brakes, release parking brake, put the tranny in either D or R, no "buzzer".....
No idiot lights, all gauges reading ok, my VMSPC program shows all good, no logged codes...
Allison, Freightliner and my buddy who was a National RV Tech all say "I got nothing......"
I'm confused..... Any ideas?????
Maybe the previous owner installed a buzzer to warn of driving with parking brake engaged?????
2001 National Tradewinds, 37'DP, CAT 3126B, Allison 3060, Freightliner chassis
2017 Montana High Country 375FL
2015 Ram 2500 Heavy Duty, Cummins 6.7, factory tow package, factory snow plow prep package
20 REPLIES 20
Pass42
Just ordered the new pressure switch from Freightliner.... part #06-31933-000 for the parking brake alarm chime, only $127.12, shipped to my house
The other pressure switch, for the parking brake alarm light is #KYS10420833040
howdy35
Pass 42 Sorry I can't tell you where the buzzer is located, but on my Tradewinds my dash can be pulled forward a little bit so I can see inside. I just looked down there and found the buzzer that was making the noise and took it loose. It has been 3 years or more since I pulled it.
My dash is held in place by Velcro so it is easy to pull forward and have a look. Tcooper mentioned where one of the sensors is located. You might check that also. Hope that helps.
Sorry, I had not read far enough to see the solution. I may now check my coach as I believe I was having the same problem you were having.
Arnold
1999 National Tradewinds 7370
2014 Honda CR-V--Toad
Fulltime
Pass42
Well - Problem Solved (I think) Called Freightliner for the second time... got a different tech guy... he said just forward of the rear axle, drivers side, on the frame rail is an air manifold.. it has a pressure switch out of each end.. the one with the spade connectors is the parking brake light, the one with the 3" pigtail and connector is the parking brake chime switch... he said that switch is going/went bad... replace it and problem should be solved... for right now, I just disconnected the pigtail connector... hopefully, that will work til I get a switch. Thank you everyone for the hints, tips and ideas!!!!
gsf35099
I wonder if it's like what someone mentioned earlier. The Leveling System.
My leveling control board would intermittently buzz a while back. My jacks rear were not all the way up. Just a thought
2005 Damon Astoria 3679
300 Cummins ISB 5.9, Allison auto 5 speed
Life is to short not to have a good time and enjoy!!!
Pass42
Arnold - where under the dash?? What did it look like... there is sooooo much "stuff" under the dash, I can barely find anything.....
Pass42
I actually called Freightliner, with my VIN, they said the only buzzer was the loud one used by the low air warning....
It appeared, at first, that the order in which I released parking brake, etc made a difference.....not anymore...
Usually we can start driving, with no buzzer/beeper, than after an indeterminate period of time the sound starts... sometimes it will stop on its own, sometimes not... sometimes for a short while, sometimes for miles and miles... sometimes the sound is louder than others.....
fcooper
As suggested by Wolfe10, if your chassis if Freightliner, call the Freightliner help desk (free service). Have your vin number handy so that they can find your chassis records.
I had that problem, and the sensor was located along the frame rail, driver side, just in front of the rear axle.
Freightliner help desk number is 1 800 FTL HELP.
Fred & Vicki
St. Augustine, Florida
Ernest
I would check the level in your jacks reservoir in the compartment behind the street side duals. It should be up to the level of the nut you remove to check the level; the jacks must be retracted "up".
If this is ok and you air pressure gauges are reading properly then you have either a bad level sensor on the jacks or a bad airbrake sensor.
I personally start with the level sensor first. Then move on to the airbrakes.
Ernest & Joanne
2000 Tradewinds 300 CAT
2014 Jeep Cherokee Limited
Travelingonthetradewinds.blogspot.com 2014 Alaska Blog
Travelingonthetradewinds1.blogspot.com 2017 South West Blog
howdy35
There are several different buzzers you can get with the National 7370. First,the buzzer you get when the air is not up enough to travel and that buzzer will stay on until the air builds to sufficient level. Usually 135 pounds. The other buzzer is a result of low fluid in the jack reservoir. With the jacks up, check and fill the reservoir. Another buzzer is the result of the parking brake sensor not recognizing the air is up and the brake is off.
I had the last problem and could not find the sensor so I found the buzzer under the dash and disconnected it. Someone said that sensor was underneath near the back left side tires. Didn't find it so now, when my parking brake is on and I put it in D I have no buzzer. I just have to remember to take off the parking brake.
Hope this helps. Arnold
Fulltime
usersmanual
Pass42 wrote:
OK - except the buzzer/beeper does not stop... we drove for 8 hours today with the on/off beeper noise coming out of the dash...no beeper in neutral, however, beeper in D or R... parking brake off... everything else is normal...
I was thinking maybe seatbelt warning... never put on Nationals
at a loss as to what else... maybe a bad connection/loose wire in parking brake alarm circuit????
well thats not what u claimed in your first post you claimed quote:
Tinstar
Mine does that and Brett Wolfe answered with the correct 'answer' as to what mine is.
:CNever pass up a chance to go somewhere:C
wolfe10
A possibility.
Contact your chassis maker (likely Freightliner) with your VIN. They can tell you want to check.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Pass42
usersmanual
as previously noted here its supposed to do that my 2008 isl sparton does exactly the same thing warning your in gear with park brake on
