โMay-29-2013 07:07 AM
โJun-01-2013 07:09 AM
โMay-30-2013 10:11 AM
โMay-30-2013 09:07 AM
โMay-30-2013 08:36 AM
Daveinet wrote:RCMAN46 wrote:I don't think that Jeep video applies to a motorhome. It really depends on how bad it is stuck. If it will almost get out on its own, but just needs minor help, the axle isn't going to come off the vehicle. If the differential is on the ground, that would be a different story.
DO NOT ALLOW the tow driver to attach anything to the front axle! My father had a towing business. He had an inexperienced tow driver hook to the front axle of a truck stuck in the mud. All that came out of the mud hole was the front axle. The truck stayed in the mud hole. My father had a very expensive repair to pay for because of that error. There is a You Tube video of the front axle being pulled off of a Jeep that was stuck in a mud hole. Jeep axle failure
โMay-30-2013 08:28 AM
โMay-29-2013 11:50 PM
โMay-29-2013 09:05 PM
jhilley wrote:
Here is benefit from their WEB site
"Winching
Winch out or extraction services required in order to tow the disabled vehicle. Covered up to 100 feet off of a maintained road or in a commercial campground equipped for camping vehicles."
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
โMay-29-2013 08:00 PM
โMay-29-2013 07:55 PM
โMay-29-2013 06:56 PM
โMay-29-2013 01:17 PM
โMay-29-2013 01:03 PM
โMay-29-2013 12:49 PM
โMay-29-2013 11:23 AM
msmith1199 wrote:Rich D. wrote:C20 wrote:
Thank you all. I looked up towing companies here and there is one that does heavy trucks and rv's. ill ask coach net if we can use them. I got stuck once at talladega and a little one ton wrecker pulled me out but he was able to hook on the back at the hitch. Not so now.
I'm sorry if I double posted. Didn't mean to.
NEVER attempt to pull out a stuck motorhome by having the wrecker hook up to the hitch! Remember that the hitch has a rating much, much lower than the weight of the motorhome! For example, my last coach had a 10,000 lb capacity hitch and weighed 50,000 lbs. Attempting to pull 50,000 lbs with it could make for a catastrophic failure and rip the hitch right off.
If the operator can get under the front, they can safely use a wheel lift to raise the front and pull it out. Also remember that the frame may be located up quite high (over the storage compartments) and many have a removable panel at the front that exposes a tow point on the frame.
But that's a 10,000 pound rating for towing something at highway speeds. That doesn't mean if you tow something over that weight that the hitch is going to fly off. However, I would agree you have to be careful when pulling a 50,000 motorhome no matter where you attach the tow hook. I'd have no problem using the hitch as long as the truck operator pulled smoothly and as long as I was helping by driving the coach out of the mud.
