Per everybody's suggestions, we started the empty holding tanks with a couple gallons of anti-freeze, then waited until they were real full before dumping. It worked great!
The problem was the bathroom pipes.
The walls, floors, and cabinets with the bathroom pipes are in the back rear of the RV. They are completely sealed and unheated. There is a heat duct in the bathroom, but zero heat in the plumbing enclosure.
We dodged around western Montana and managed to camp no colder than 30 degrees F. We also had the good sense to unplug the electric space heater and run the furnace so the duct put out heat. No help.
The toilet line froze. The bathroom sink had almost froze thru when I turned it on and cleared it with warm water. I suspect the shower froze (but when we got around to showering, it was warm enough that water ran. However, the shower P-trap froze and it wasn't until my wife shower filled the pan with warm water that the p trap thawed and flowed.
Our leak appears to be the screw on hose connection for fresh water. It was on its last legs and I have a replacement part on hand at home. I think the cold weather pushed the spring loaded seal to its end of life.
I am still going to install holding tank heaters and blankets.
I am also going to install a new supply connection and shower faucet, and, when I do so, wrap the lines with pipe insulation as much possible.
Additionally, I am going to "Y" one of the rear furnace ducts and route it into the plumbing enclosure to warm the pipes.
My cold weather plumbing problem wasn't where I expected it to be. Go figure.
