โMar-06-2016 04:06 PM
โMar-07-2016 05:31 AM
โMar-07-2016 04:42 AM
fcooper wrote:
bmwbob:
First of all, I have not changed the bell crank, so I can not comment on that.
Your rig (from your profile = 1999 Newmar Dutch Star 38' diesel pusher) will be on basically the same chassis as my motorhome. I've chased the same problems, and have solved them without replacing the bellcrank. Mine seemed to have excessive steering play.
Yes, the Koni FSD helped the ride a lot. After a good alignment, I still had the problem you described. After checking for worn components, I determined the loose feeling was from the steering gear box. Luckily, it is adjustable. After minor adjustment, it tracks much better.
I could still feel the tires following the ruts in the road (very minor problem) and installing a Steer Safe cured that problem.
Adjusting the steering gear box is a controversial subject. Some authorities claim you must remove the box and make adjustments off the rig to get it right. Many shops refuse to adjust the steering gear box. There are a number of Freightliner chassis owners that have realized improvements by adjusting the excess slop out of the gear box without removing the gear box. The adjustment is on the side of the gearbox, with a hole in the frame member provided to allow access to it. Make very minor changes and test drive. It's better to be a little loose than too tight.
There is additional info about this on the Freightliner Chassis Owners Group on IRV2.
I've had the Steer Safe damper on the rig for quite some time since I originally thought that my wife would be sharing the driving (NOT!).
I can recall adjusting the steering gearbox wear adjuster on older cars I owned many years ago. The shop that put my Koni shocks on is honest and competent. I think I'll consult with their wrench about doing the adjustment since there seems to be such a difference of opinion about it here.
Thanks for all the tips! This is a GREAT place for avoiding reinventing round discs with holes in the middle! ๐
Bob
Fred
โMar-07-2016 04:35 AM
โMar-07-2016 04:32 AM
RayChez wrote:
Are you sure it is the bell crank and not the tires?
โMar-07-2016 04:29 AM
โMar-07-2016 03:53 AM
โMar-07-2016 01:55 AM
bmwbob wrote:
Does anyone have any experience with these units?
After the marked improvement from the Koni FSD shocks, I looking now to eliminate the constant back and forth movement of the steering wheel needed to keep the rig on a straight track.
And, do I need to have them put on both sides of the rig?
Bob
โMar-06-2016 08:18 PM
โMar-06-2016 06:25 PM
SacsTC wrote:
I don't think that Henderson's makes a Bellcrank for Freightliner chassis. They are for P-30 and P-32 motorhomes.
โMar-06-2016 06:03 PM
Bud
USAF Retired
Pace Arrow
โMar-06-2016 05:57 PM
โMar-06-2016 05:38 PM
โMar-06-2016 04:56 PM
Bud
USAF Retired
Pace Arrow
