โAug-29-2016 05:33 PM
โAug-30-2016 04:17 PM
tempforce wrote:
i can't believe your vehicle paperwork recommends 3,000 mile oil changes.
the only people who promotes that, is the oil change places..
i would check with the engine manufacturer and use the heavy use recommendations. it should be between 5,000 - 10,000 miles depending on engine and use.
my current vehicle gets a yearly oil change. the oil still looks clean when it comes out, it goes into the yard equipment after running through a centrifugal purifier.
โAug-30-2016 03:31 PM
jolooote wrote:
If you cahnge oil every 3500 miles as I do, its a waste of money to change to synthetic unless you change the interval to about 10000 miles. I've been told that once you change to Synthetic oil you can't go back to dino.
โAug-30-2016 03:22 PM
2020 Jayco Greyhawk Prestige 29MV Celestial Blue Full Body Paint E-450 305hp V10 6spd Class C 'COACH'
โAug-30-2016 03:16 PM
โAug-30-2016 03:05 PM
howdy35 wrote:
I had a 1999 Bounder with a V10 and I ran Amsoil in it. I used their premium filters and ran it 15,000 miles between changes. Never a problem and on our trip to Alaska in 2002, no oil change on the road. I now run Amsoil in my DP and all my cars. I changed my Bounder over to synthetic as soon as I purchased it in 2002.
I think you need to lengthen the miles between changes to at least 10,000 miles or the extra cost is not worth it. Changing over to true synthetic will clean any drudge your engine may have in it so you may want to change the filter at 5,000 miles just to be safe on the changeover.
โAug-30-2016 09:39 AM
โAug-30-2016 09:38 AM
โAug-30-2016 08:41 AM
โAug-30-2016 08:02 AM
โAug-30-2016 07:10 AM
โAug-30-2016 07:04 AM
somewhere in the texas 'lost pines'
โAug-30-2016 05:36 AM
โAug-30-2016 03:29 AM
โAug-30-2016 12:49 AM
โAug-29-2016 11:32 PM
