โOct-16-2014 08:57 AM
โOct-16-2014 11:56 AM
rgatijnet1 wrote:PaulJ2 wrote:
Need some history here. Was it a constant problem that has gotten worse? Or did it just start to overheat suddenly? What parts were replaced for that money?
Can only guess without more information. Some details please.
Ok, see it overheats almost at once. Agree no water circulation.
Did they replace water pump with the wrong one? Serpentine belt driven pumps operate counterclockwise, v belt ones operate clockwise. They have been known to mix them up.
Usually I would rule out the water pump in this situation but you do bring up a good point. The GM engine is used in Marine applications which means they have CW and CCW rotation engines. Many GM water pumps are bi-directional but I guess it is possible that the wrong water pump was installed. A check of the water pump part number should confirm if it is the correct part.
Naturally you want to check oil pressure. A failed oil pump can cause things to get hot quickly.
โOct-16-2014 11:35 AM
โOct-16-2014 11:16 AM
โOct-16-2014 11:09 AM
โOct-16-2014 11:01 AM
427435 wrote:rgatijnet1 wrote:
If the engine overheats in a little over a mile, that indicates that you are NOT getting water circulation. This eliminates the fan clutch, transmission, dragging brakes, etc.
I would look at things that will stop the water from circulating like a bad thermostat or an air pocket in the cooling system that will cause the water pump to stop pumping. Check the thermostat with a pan of hot water to make sure that it opens completely and that it is installed correctly, and not backwards. Fill the system with water and properly bleed it to make sure that all air is removed.
Good suggestions.
The bottom radiator hose could be collapsing or plugged. Make sure that there are new hoses in that $5000 worth of parts.
โOct-16-2014 10:44 AM
โOct-16-2014 10:27 AM
โOct-16-2014 10:23 AM
โOct-16-2014 10:07 AM
โOct-16-2014 09:56 AM
hanko wrote:
water pump?
โOct-16-2014 09:49 AM
rjxj wrote:
Did they check the head gaskets or cracked head. You could probably have done a crate engine for near that money.
โOct-16-2014 09:46 AM
โOct-16-2014 09:36 AM
newman fulltimer wrote:
did they ever check the transmission to see if it is the cause?
โOct-16-2014 09:29 AM
