May-24-2020 01:36 PM
Apr-17-2021 03:38 PM
Apr-16-2021 07:45 AM
srx-6 wrote:
I have all 3 new Penguin II units installed and running (all zones and all modes). I purchased a separate control module to be used with the auto generator start feature. What I did not know is that I need a "wiring kit" for the extra control board. Will be looking for one of those this week.
In the process of replacing the ac's I have lost power to the Magnum energy display that is attached right below my new T-stat. At first the T-stat would not work but found a bad fuse. The fuse for the EMS is good. I looked for a fuse at the Magnum unit in the bay but did not find one.
Any ideas would be appreciated.
Apr-15-2021 11:14 AM
ThruTraffic wrote:dougrainer wrote:
Your tstat and Communication cables and roof top controls are specific to Dometic. If you go to another Brand, you will have to run new Tstat Cables from the wall to the roof and change out the wall tstat and the upper control boards, which adds cost.
Not exactly true. the Penguin II and CCC2 for example use a 4 conductor RJ11 (phone) connector. They don't even supply this cable you have to make one and run it UNLESS your old system has a cable already run with at least four spare conductors. If you have the spare conductors just buy some RJ11-6p4c connectors and attach your old wiring to them. The Penguin installs doc has the wiring pin-out for you to do just this. Odds are you won't have to run wire in a change out; new install, yes.
Apr-15-2021 09:10 AM
Sep-14-2020 11:43 AM
srx-6 wrote:
The only COMM cables I disconnected were the ones at the ac. I have checked all the COMM cable connections at the inverter, Auto start module in the front electric compartment and at the remote. All appear to be good.
I am wondering if the extra control board needs to be wired in and the generator dip switch activated to power up the Magnum remote.
Sep-14-2020 11:19 AM
Sep-14-2020 09:02 AM
Sep-14-2020 08:54 AM
Sep-05-2020 04:30 AM
dougrainer wrote:srx-6 wrote:
The new Penguin II units have finally arrived (ordered them June 15). I am thinking I will pull them up to the roof with rope and sling. Can anyone tell me if the units must remain flat or can they be turned vertical for the trip up the ladder?
They can be turned vertical for a few minutes. Doug
Sep-04-2020 01:50 PM
Sep-04-2020 11:48 AM
Sep-04-2020 10:21 AM
May-29-2020 08:01 AM
A1RVTraveler wrote:
Is seems silly to remove three brand new circuit boards from three new AC units and then install three used boards from 12 year old AC units. The correct plan is to buy a new 10-button thermostat for less than $100 and upgrade your entire system. It's all plug and play.
Where is the $500 savings?
May-29-2020 07:57 AM
srx-6 wrote:
Not sure what they are. My paperwork states Dometic / Duo Therm ac and heat pump model #630516.331. I can see the control boards so should be easy to remove
