Tire blew and destroyed storage box
tommymontes
I have a 2002 Winnebago Sightseer with the Ford chassis. Tire in rear on passenger side blew out last week and destroyed the exterior storage compartment. The storage compartment door is still in tact but the box itself is crumpled. I took a look in the Winnebago catalog but couldn't find anything on purchasing a new storage box. Is this something that can be purchased and bolted in as a replacement part? I'm thinking someone else had to have had a blowout before and incurred the same damage as I.
I appreciate your advice. Thanks.
~Tom
13 REPLIES 13
FIRE_UP
~Tom
Tom,
Yep, we've had two blow-outs on our coaches. One, a class C Ford going down the front side of the Grapevine in northern LA Cal. The other, about 20 miles south of Bakersfield CA. Both did extensive damage to the wheel well compartment areas and, in the first one, it damaged the shower pan and, the fresh water tank.
Since we carry a high deductible, I did the repairs, on both rigs, myself. On the first one, the Class C, I simply cleaned up the fiberglass shower pan and, laid in more glass. It looked flawless when done. As for water tank, it was made (and some still are) of Poly Ethelene plastic. That kind of plastic can be WELDED. So, since I only have welding equipment for all steels and no plastics, I had to farm that one out. It cost me a whopping $50.00.
But, in both cases where compartments were damaged, those repairs were simple. I purchased the same gauge galvanized sheet metal, in the largest form I calculated I needed. Then, I drew out the sides, bottom and top, calculated the appropriate bends and, headed to the local sheet metal fab place. The sheared it, bent it at my bend calculations and, I headed home with all the correct sized pieces.
I put them all together with rivets. Some sealer in the joints and, it was all done for around, $150.00 and, I had a brand new compartment. I purchased some "under coating" in a can and sprayed the back sides for protection against the elements. Looked better than new when done.
Scott
Scott and Karla
SDFD RETIRED
2004 Itasca Horizon, 36GD Slate Blue 330 CAT
2011 GMC Sierra 1500 Ext Cab 4x4 Toad
2008 Caliente Red LVL II GL 1800 Goldwing
KI60ND
kmowen
Those things sure create a lot of damage when thet blow, had a left front blow on mine and what a ride. The compartment wall on mine was damaged but I repaired it with an aluminium sheet myself. On a previous Coachmen I had I went to a fabricating shop with measurements and they built me one from aluminium for around $200 that just slid into opening and I screwed it to the outside frame, worked great, I'm sure any fab shop could build you one. Good Luck with your repair.
06 Allegro Bus
07 Envoy Toad
ddndoug
Just for curiosity sake... how old are the tires?
Doug
2009 Four Winds Hurricane 33T
F53 Ford Chassis w/Triton V-10
Frosty_s_Mom
we had a winnebago class c that blew out an inside dually destroying the compartment adjacent. VERY scary! RV obviously not as expensive as y'all describe, but thankfully the insurance (geico) called it an accident and paid to fix. the repairs looked pretty decent and everything worked after that and i don't have to nag DH as much to ck the tires anymore.
wee3-gin, clyde & the bichon frise
2002 Forest River Windsong-34' Class A
Workhorse 8.1 W22 with Allison Tranny
1996 Geo Tracker-4WD--"Trudy"
2003 Minnie Winnie 30V - "The Frosty Hauler" (Class C)
May the Angels guide your wheels and ride on your shoulder.
Hikerdogs
Parts are available from Winnebago. We had the factory service department replace the entire Storemore cabinet under the drivers side slide, and the sheet metal behind the storage cabinet doors on the passenger's side. I doubt that you'll find them in the parts manual. If you call customer service they can fax or e mail you a drawing of the cabinets. You can identify the parts you need.
In our case we didn't have to order anything because we took the motorhome to them for repairs.
Hikerdogs
2013 Winnebago Adventurer
wallynm
Not the same PSI in the tire and the blast is smaller because the tire is smaller.
Francesca Knowles wrote:
wallynm wrote:
A half million dollar RV does not have these kinds of problems. It is the less than half million dollar RV that have this problem.
I've never figured out why the "rules" seem to be different for RV's than for cars.
If armoring a wheel well is so bleedin' expensive/difficult, why doesn't, say, a $10,000.00 Hyundai "have this problem"?
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
ArchHoagland
My insurance (CSAA) covered the damage from my tire blowout...$12,000.
Check with your insurance company.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
sehunter
Would your insurance cover your loss?
Stan
2008 Bounder
38P, W24, 8.1L, 3 Slides
2019 tow dolly hydraulic brakes
robatthelake
A Quarter inch thick Steel Wheel well would weigh how much?
Maybe a 16 gauge wheel well might make more sense.
In any event the stuff they use is pretty skimpy for sure!
Rob & Jean
98 Dutch Star Diesel Pusher ..07 Honda CRV AWD
Francesca_Knowl
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
wallynm
down home wrote:
This is one thing that continues to puzzle me. A quarter inch steel wheel housing would save lots, of destruction, in RVs and even lives, yet Mfgs haven't addressed the situation.
I'm in no situation to do it now or I would have something like it built into our MH. What's 500.00 in a 500,000.00 or greater RV.
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
down_home
wallynm
RV Salvage
Check with these guys.
~Tom
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
