Sep-03-2013 06:54 AM
Mar-27-2014 12:28 PM
Mar-27-2014 09:38 AM
Mar-27-2014 08:59 AM
Mar-27-2014 06:02 AM
Mar-27-2014 05:52 AM
willald wrote:sammy64 wrote:kalynzoo wrote:
My concern: Isn't the Caravan rather overweight for the rating of the dolly?
Just mentioning.
how could it be overloaded? the mini van is probably one of the lightest things to tow (other than a preaus) thanks
No, minivans are not light, compared to a regular car.
Most minivans are going to weigh around 4400-5000 lbs. Your 2011 Caravan's curb weight is listed at 4510 lbs when I just checked.
Many dollies are only rated to handle up to 4000 lbs, some less than that. There are only a few dollies out there that can handle a 4500 lb car or minivan like yours.
Soooo, yes, it is quite possible, that you are putting more weight on your dolly than its designed to handle.
Anyway, back to your original question: One thing you may want to consider, that would alleviate both the fender rubbing issue as well as the potential weight issue: Sell that dolly you have, and get you an Acme EZE tow dolly. I know for a fact that fender rubbing is just about impossible with the way the Acme dolly is designed (I used to tow a minivan on one). And, it is one of the few dollies that can easily handle 4500 lbs of vehicle, yet still be light enough to keep you from going over the 5,000 lb maximum most MH hitch receivers have.
That'd be my recommendation, if the board stacking idea previously mentioned won't work.
Mar-26-2014 03:39 PM
lesliericker wrote:
We just tried our 2013 Sienna Van on a Master Tow 80THD. Had the same problem When turning, fenders rubbed (badly) the sides of our van even with a nice, wide turn. Did you ever find a tow dolly that would work? We are still looking at the Roadmaster 2000-1, the ACME EZ-load or possibly the Landgrebe tow dolly. Anyone have any experience towing the Sienna and using a tow dolly. We are 78.1 width....
Any advice would be greatly appreciated.
Thanks.
Mar-26-2014 03:28 PM
Sep-03-2013 04:21 PM
Sep-03-2013 03:37 PM
tomousecap wrote:
Tow Dollies Model 77T Model 80THD
Vehicle Tread Width 40” – 77” 40” – 80”
Max Width at Front Doors 75” 78”
Overall Width 99” 102”
Overall Length 121.5” 121.5”
Height at Fender 26” 26”
Ground Clearance 6.0” 6.0”
Weight 450 lbs. 551 lbs.
Tow Dolly Gross Vehicle
Weight Rating 3,000 lbs. 3,500 lbs.
Actual Cargo Capacity 2,550 lbs. 2,950 lbs.
Maximum Gross Weight of
Vehicle to be Towed 4,250 lbs. 4,900 lbs.
Tire Size (Trailer Service) ST 205/75D 14" 6 Ply Rated
Coupler Size 2” 2”
Coupler Class SAE 2 /3,500 lbs. SAE 3 / 5,000 lbs.
www.mastertow.com
This chart is on "Master Tow's" website. I use the model 80THD and it clears vehicles up to 78" wide at the doors. I think you have the narrow model and need to do your homework. The capacity of the dolly is Ok. It is the width you need to look at. Also be advised that if you fail to secure the steering wheel from turning, it will allow the dolly tray to pivot into the body because of the front wheels turning. It will also loosen the tie down straps if the steering wheel is not locked.
Sep-03-2013 02:37 PM
Sep-03-2013 01:59 PM
Sep-03-2013 01:55 PM
FIRE UP wrote:sammy64 wrote:
ok i have a problem, mom has a 2011 dodge grand caravan and she wants to dolly it behind her motorhome.... BUT she had a "tow master" dolly and the van fit fine on the platform BUT she couldnt turn ANY corners because the fenders of the dolly would hit the doors on her van, now i loaded my full size dodge truck on the dolly and it worked fine because the fenders on the dolly went under the fenders on the truck...
Does anybody tow a 2011 dodge grand caravan ??? ive seen some on the highways but they were going the other way so i couldnt look and see what year the van was or the type of dolly they had... thanks for any help...
Well Sammy64,
I've seen no answers to your inquiry about your fender/door/sill clearance problem on your dolly so, I'll just throw my 2 cents in for the heck of it. I don't know how much it would throw the geometry of the dolly tow/carrying system off but, here's a thought. What if you put say, a section of 2x10 or 2x12 on top of where the front wheels would sit on the dolly??? Would that raise the front end of the van enough so the fenders would clear the doors/sills of the van when turning?
All it would mean would be that the front of the van sat about an inch and a half higher than it would be normally. To me, that would be no big deal at all but, I don't use a dolly so, I've not had to deal with your issues here. I certainly can't see any problem with putting a piece of 2x12x say, 12" long on each wheel platform. If it doesn't work, well, it's on to plan B.
Scott
Sep-03-2013 01:48 PM
Just mentioning.
Sep-03-2013 01:45 PM
Just mentioning.
