Jan-24-2016 10:00 AM
Feb-04-2016 05:44 PM
Ivylog wrote:
Not many gassers over 37' as that's about the max weight for a V10. That said there was a recent post about a 40' Tow Hauler that even had a decent amount of CCC partly because of the empty space in the rear.
"Diesels can get very expensive for both Maintenance and Operation"... I have not found that to be true, but I do all of my own M and O plus repairs. I would go back as many years as necessary to find a mid level DP.
It will be interesting to see how much this no reserve .......Monaco Signature goes for... my educated guess $115K for a 03 top of the line maxed out DP.
PS: you will not find a bath and a half in a gasser.:B
Jan-25-2016 10:17 AM
mike brez wrote:barmcd wrote:the silverback wrote:
Lots of talk here!! How about getting the floor plan that best suits your needs. than worry about gas or DP.
Not for me--there are about a million floor plans that could work for me, but if I don't like driving it, the floor plan doesn't matter.
X2 no way. After owning my gasser for 14 years and not liking the handeling,brakes and engine noise a DP that drove and handled nice was number one on my list.
Jan-25-2016 09:55 AM
Mondooker wrote:. That is a good start. During the the 5 mos of travel how much time do you plan on remote CGs like NPs, NF, SP, or COE type CGs (dry camping) vs RV resorts or private CGs with full hook ups? What kind of tow car do you want a small car that gets good gas mileage or a large SUV? How you answer these and other questions will help you decide.
I just read the information by Johnny T., and it was excellent. I intended to read it before and somehow forgot it was there. One thing I should have included in my earlier post is "Fit & Finish" and is something very important to us.. We are retired and our time is our own but we do plan to spend a good amount of time in our motorhome. Maybe up to 5 months.
Along with the fit and finish we also want a coach that allows access to main areas when underway. One other thing of importance is a washer & dryer and NOT a combo.
By golly I'm starting to learn something and they say it couldn't be done!
Jan-25-2016 09:13 AM
Jan-25-2016 07:59 AM
Jan-25-2016 07:30 AM
Jan-25-2016 07:10 AM
Jan-25-2016 06:57 AM
Mondooker wrote:To answer your question directly it would be a DP if you want 40 ft. As a first time buyer I would be asking a different question. What MH would meet my needs and how would you like to camp. I see you live in Florida not many hills there or pot holes. Are you still working? How much travel will you do outside of Florida? I would also suggest you read and study the 1st sticky at the top of this forum by Johnny T called "first time buyer" he explains in detail gas vs diesel MH's advantage and disadvantage of both. It dispels a lot of myths and takes the emotion out of the debate.
Since joining the forum I've asked a lot of questions and received great answers. And when asking questions about something new, other questions come up.
One recommendation I received was buying a newer model Gasser instead of an older model DP. This is my first motorhome and I want something around 40 feet and want to spend no more than $100,000.00.
As I'm looking at used upper model Gassers, which i'd not done before, like Tiffin Allegro and Newmar Canyon Star. I found that the base models of Diesel Pushers are around the same price.
My question is "what's a better move for a new-be, a top of the line used Gasser or the used base model Diesel Pusher"?
Your help has been invaluable, thanks you!
Jan-25-2016 06:56 AM
Jan-25-2016 06:33 AM
Jan-25-2016 06:27 AM
-Gramps- wrote:Mr.Mark wrote:-Gramps- wrote:
Don,
I have owned the coach for nine years. It may have cost more than most gas buyers wanted to spend, the marketing may have not worked but the design is very good. There are hundreds of them still on the road (not that you would know if you saw one), very few are for sale anywhere because most owners keep them. I met an owner of a Winnie UFO yesterday. He pulled in from Roanoke on his way to Key West. Loves his GP.
My coach is 39.5 feet long, 22.5 tires, tows 10,000 lbs Allison 2000 tranny, and climbs a 7 percent grade faster than most motorhomes or trucks. It also has a computer controlled counter-weighted torsion box suspension that keeps it upright on tight curves. It has quad piston pressurized brakes and it will stop faster from 60 to 0 than a dp the same size.
Gramps, I think a Gas Pusher is a neat idea and I'm glad that you like yours.
But, a 60 to 0 stop comparison has to be done by weight, not size.
Our 45 ft. DP has a 'retarder' with 6 speeds. Most other DP'ers will have a 2 or 3 speed jake brake. The six speed retarder is stronger.
You will not find a 55,500 lb. gasser like our DP. We can stop extremely quick for our weight when using our 6 speed retarder, it has automatic activation when using the service brakes.
MM.
I was referring to same weight rating, poor choice of words I guess. I am not going to compare my coach to a 55,000 lb high end diesel anymore than I would compare a 325hp entry level diesel to a Road Trek class B. Its not apples to apples
Maybe this article might be interesting to you.
Its one of the reasons I purchased the UFO and the brakes have saved me more than once. I also have a grade brake...meaning when the grade brake is turned on, when going downhill I can tap the break pedal, the brakes do not engage, the transmission downshifts instead.
Union City, November 28, 2006 -- The conventional wisdom is that the air brakes on a rear diesel pusher motor home can beat anything mechanical found on a gas-powered motor home. If you want the best in stopping power, that's the way to go.
This is among the assumptions the new Workhorse UFO™ chassis has just shattered. Test data indicates the Workhorse UFO™ HPB Quadraulic™ four-wheel anti-lock disc brakes are superior to the competition's air brakes.
Results from head to head tests performed at the Bosch Proving Grounds in South Bend, Ind., have been released by Workhorse Custom Chassis. They show the Workhorse UFO™ coming to a complete stop more than a coach length sooner from 60 mph than the competition's rear diesel pusher.
Here are the facts:
" Coach on Workhorse UFO™ 26,000 lb. GVWR loaded to 26,000 lb.: Stopping distance, 60 mph to 0 mph, 189 feet.
" Similar coach on competitor's 28,000 lb. GVWR rear diesel pusher with air brakes and loaded to 26,000 lbs.: Stopping distance, 60 mph to 0 mph, 238 feet.
Difference: Workhorse UFO™ stopped 49 feet sooner.
"RVers driving big rigs want brakes they can trust to perform well in all kinds of weather and other conditions,"? said Bob Wert, Workhorse vice president of sales and marketing. "They haven't been mentioned much, but the stopping power and car-like touch of the Workhorse UFO™ brakes are some of the persuasive attributes for anyone who drives this chassis."?
Workhorse Custom Chassis is ISO 9001 certified and a leader in the manufacture of chassis for motor homes, walk-in trucks and buses. It is a wholly owned subsidiary of International Truck and Engine Corporation. International produces IC brand school buses, school bus chassis, mid-range diesel engines, International brand medium and heavy trucks, and severe service vehicles. International also provides parts and service sold under the International® brand. Both Workhorse and International are subsidiaries of Navistar International Corporation (NYSE: NAV). For additional information call 877-294-6773 or visit Workhorse.com.
__________________
Jan-25-2016 06:08 AM
Jan-25-2016 05:58 AM
Mondooker wrote:
Ivylog you sure pay attention! You are exactly right and have been a great help to me!
Jan-25-2016 05:57 AM
