โDec-10-2009 06:16 PM
โDec-09-2010 01:51 AM
rondeb wrote:Yeah I tried that a few months ago and after about 6 days I started getting and I mean really sick, Something in that med was making me sick, I have heard of other people that it worked great for.oldtrucker63 wrote:
Trying to Quit smoking today, Cold Turkey, Started just a few Minuets ago I hope this go's good.:R Most of all I hope Charlene gives it her best, She is on the train with me, Together we can do this.:p
I would like to suggest that you see a doctor and get a prescription for Chantex. You start taking it, and you will notice that you start smoking less and less and then after 30 days, you don't smoke again. It is absolutely the only thing that truly works on your brain to help you quit. I took it for 3 months and haven't smoked since and that was 3 years ago.
Trust me this is the way to go.
โDec-09-2010 01:47 AM
14yuTrk wrote:I wish I had quit 35 years ago, Hell even 10 years ago. Money Money Money, OH Yeah.:ooldtrucker63 wrote:
Best choice you ever made. You can do it. luck has nothing to do with it will power and determination will do it.
I gave it up thirty five years ago after I determined I could do it.
Money I saved would buy me a decent RV.
Mickey
โDec-09-2010 01:45 AM
4Eddielee wrote:I may run this cable just in case, Good tip.
If you run the cable for a video camera from front to back while the rig (walls/roof) is open, makes it a lot easier later IF you decide to put in a system - you don't have to install either a camera or screen if you don't want to. But if you later change your mind.....well, thinking ahead now can pay dividends....
Weighing the rig - you should try for 60% of the total loaded weight ahead of the centerline of the rear axle. However, the lighter the rear end is, the more it will bounce - think unloaded pickup truck. A friend of mine had so much bounch he moved the rear axle rearward 12 inches. Just make sure that the water, black and gray tanks are over or slightly ahead of the rear axle. As they fill up they can pick up the front axle enough to destablize the steering. Remember, water weights right around 8 lbs gallon. Black and grey water is a slight bit more. The further aft they are, the more it will cause steering problems but will reduce the bounce. The longer your rigs rear overhang (axle to rear bumper), the greater the weight distribution becomes critical!
โDec-09-2010 12:42 AM
chinook440 wrote:Thanks man, I good luck to you also, Take a look at all the things that is in cigarettes, Ammonia
Good luck to the both of you.
i plan on riding the bandwagon AGAIN myself after the holidays.
It aint easy , it,s the worst addiction there is .
โDec-09-2010 12:29 AM
4Eddielee wrote:Then I will have to keep an eye on the rear axle weight because the gray and black tanks will be 3 feet behind the rear axle, Although they are not all that big it might be ok, I will watch this.
โDec-08-2010 06:42 PM
oldtrucker63 wrote:Best birthday present I gave myself in Jan 1996. Gave myself about 3 more years of life. :B
โDec-08-2010 05:13 PM
โDec-08-2010 03:29 PM
โDec-08-2010 03:23 PM
โDec-08-2010 01:44 PM
โDec-08-2010 01:25 PM
โDec-08-2010 12:58 PM
โDec-08-2010 08:43 AM
โDec-07-2010 12:27 PM
tboss wrote:I have give this thought, But I believe I will pass on this, I have two cams now that would work but needs a screen for up front, But I'm going to skip this one.
hey driver a rear backup camera is a handy yhing to have for backin and towing,,I have one and it is really nice to see what is directly behind you..esp. in a campground where kids are all over the place..and I can keep an eye on da toad too..
โDec-07-2010 12:23 PM
tonyandkaren wrote:At this time we are still looking.:h
oldtrucker - our 25' has both the shower and the kitchen sink along the back wall. It's fine so I think your plan will be okay too.
You're right about the vapor barrier. What are you using for the final wall finish? It's good to have that vapor tight as well.The vinyl covered luan that most manufactures use seems to do the job but I'm sure that there are other kinds of paneling that will work too.
