Tow Dolly with surge brakes - recommendations?
Wufpak204
It seems that the general consensus is a tow dolly with surge brakes for towing our Mini Cooper with front wheel drive.(our MH isn't wired for electric brakes). Any recommendations? Does anyone have the Acme EZE-Tow with surge disc brakes? It looks like a reasonably priced well designed tow dolly. Thanks.
13 REPLIES 13
blknomad
I'm with farm boy and jaxdad I back my demco car kaddy all the time and surge brakes do work. In a panic stop I've locked the wheels so they work. Two class As 2 cars same Demco dolly. Nine years and 70k miles and counting.
BennieH
Demco KarKaddy SS. Have had one for 12 years now. I am convinced that it’s the best out there. It’s not cheap, but you get what you pay for!
Bob & Pam
2003 Monaco Camelot 40PBDD
Ford Edge or Chevy Silverado toad.
Post your Park Reviews at:
http://www.rvparkreviews.com/
bjburkhalter
I sent you a private message
Brent
2011 Coachmen Encounter
STBRetired
Before we went to 4 down, had a Master Tow with surge brakes. Never had an issue in about 6000 miles of towing. Can back it up on smooth surfaces, but could have issues on bumpy terrain. Things can go south pretty quickly with the pivoting axle and short tongue so you need to be very careful if backing up, but it can be done.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
JumboJet
I bought the Acme EZE-Tow with surge disc brakes. Works very good towing a Honda Accord EX. There is a lockout device that comes with the tow dolly for backing it up if needed.
JaxDad
Farmboy666 wrote:
jules6 wrote:
I have friends who use an Acme dolly and they are very happy with it, I on the other hand have had two Master Tow dollies with surge brakes and if going back to using one I would get one with surge brakes again. By the way you can not back up when using any kind of tow dolly, surge brakes or other wise. As a matter of fact you can not back up even if you are towing four down for more that a foot or two.
I back my tow dolly up all the time for far more than 2 feet. Because you can't doesn't mean it can't be done. Misinformation is not good.
X2, X3, etc!!!
I couldn’t tell you the number of times I’ve backed up a B train of grain trailers, a LOT more than 2 feet too!
Mind you, I know I’ve met a bunch of folks who need a 40 acre gas station to fuel up a m/h too.
gargoyle158
I will throw in my 2.5 cents. I started with a Master Tow and it worked OK. Had the surge brakes and was towing a Mazda CX5. Had a blow out that completely destroyed the cheap plastic fender. Decided we wanted to tow a Mitsubishi Eclipse. Very low clearance and a long nose. Tested on just about every dolly out there and was afraid we would have to leave the Eclipse at home. Then tried the American Car Dolly. Has removable ramps to help with clearance and is very heavy and sturdy. A nice touch is an electric brake that runs off your Towing vehicles brake light connection. You plug into the towing vehicles 4way and you have lights and electric brakes. Works great.
Farmboy666
Georgia_Popcorn
I tow with an ACME, pull a KIA Sportage, two new tires, new spare, 10" wheels, Vault Bearings. No problem at all had it about 15 months, and selling...PM me if your interested
2019---35M THOR Hurricane
2016 Cadillac SRX Toad
Blue Ox
mowermech
If I had my "druthers", I would druther have a Demco Kar Kaddy.
I like the steering.
I had one, but it didn't have brakes, so I sold it.
Definitely one of the dumbest things I have ever done!
CM1, USN (RET)
2017 Jayco TT
Daily Driver: '14 Subaru Outback
1998 Dodge QC LWB, Cummins, 5 speed, 4X2
2 Kawasaki Brute Force 750 ATVs.
Pride Raptor 3 wheeled off-road capable mobility scooter
"When seconds count, help is only minutes away!"
jules6
1995brave
Surge brakes work good. You just have to remember you can not back up with them. If you try backing up with the dolly attached the brakes will activate. Have seen some that have a pin or lever to lock out the brakes so you can back up.
donn0128
I suspect you will be more satisfied with adding a brake controller and electric brakes. But frankly most people do not bother with brakes of any sort on dollies.
