TV mounts that flip down from the ceiling...........
jerseyjim
Going for a flat screen pretty soon...and have seen, in the super deluxe "mother ships" the flip down TV feature.
My gasser is 12 years old...and I wonder if the roof will support such a thing....and who makes them?
Any info appreciated.
6 REPLIES 6
dougrainer
Most of the flip down TV's are RECESSED into the roof cavity. If you try to install any type flip down without a recessed cavity, you will hit your head on the TV when it is flipped up. The mounts for most of the recessed TV's is located where your front overhead cabinets above the dash mount to the ceiling as there is usually a stud. BUT, the recessed TV's have a Steel brace/stud that is installed to help support the mechanism that folds down. Most motorhomes will NOT have a heavy duty stud, much less a Steel stud to support the mechanism. Doug
jerseyjim
Thanks for the replyes.
katoomer
Roy B.
What would make you think there is no framing in the ceiling?
What would hold up the roof?
You will most certainly find cross members of some type running across the roof
2009 Newmar Ventana 3942
2010 Pace Shadow 18ft
2010 KTM 450 XCW six days
2010 Can Am Outlander 650 XT
2014 Can Am Outlander 500
2007 Yamaha YZ250F
1989 Douglas Skater 21' Twin 2.5s
Old-Biscuit
Ceiling TV mounts........LINK
Just need to locate roof truss to mount it.
Something is up there supporting roof........
2bzy2c
If you have a really big checkbook go Here
My advice is worth exactly what you paid for it.
RoyB
You most likely will not find much support in the ceiling areas. Most ceiling consist of thin 1/4 -inch or less ceiling board without any studs to tie to...
You may have to mount a flat back board first and secure them to the ceiling area using MOLY BOLTS to spread out the weight distribution.
It can be done if you can find support from the thin ceiling.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
