TV Project
jplante4
Completed the big spring project - replacing the old head banger TV with a LED TV in a lift cabinet.
This is what I started with. The old tube-type TV over the driver's head and a lamp table a recliner behind the pax seat.
I took the lamp table out and luckily there was 120V power behind it, and much to my surprise it was wired to the inverter. I reused the wood from the table to build a cabinet to replace the old TV cab, making it the same size as the rest of the overheads.
I made back and side panels as well and put them in loosely. I need to run the cables for the CD changer that's going up there, and I think I can get the XM antenna on top of the new cabinet.
Rough install on the lift cabinet.
And with the lift up.
Final install. I had it screwed down on top of the carpet, but it was a little too wobbly. So I took the feet off the cabinet and cut the carpet out from underneath and bolted it directly to the floor. A channel for the 120V wire and the cable and now it's solid.
Added a 32" LED 1080 and project done.
Total work was about 4 days, most of it building the replacement cabinet. A good solution for the old head banger.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
19 REPLIES 19
MrWizard
Moderator
Moderator
i took out the overhead TV and use it for storage space, i built a desk behind the passenger seat for the TV and my laptop, it also has the DVD player and the Digital PVR/DVR and external hard drives
under the old TV cabinet i mounted a "flip down" LCD display, normally used for entertainment, i mounted off to the left side, more or less in line between my eyes and the windshield pillar, a $1 cable adapter couples the OEM cable to the display
its at the perfect height and easy to see
I can explain it to you.
1997 F53 Bounder 36s
jwmII
Nice job all around. What are you doing for the backup camera receiver?
jwmII
MagillaGorilla
WOW
Magilla
2005 Holiday Rambler Admiral 37' Gasser
polar76
Nicely done…
1997 32' Country Coach Allure
2014 Jeep Sahara
:C
Goldencrazy
Very nice. A great upgrade.
