โMay-11-2015 10:57 AM
โJun-09-2015 08:12 PM
Oldme wrote:
The OP said "I'm looking at a new car, but it can't be towed 4 wheels down".
That limits the OP to a dolly.
I see a lot of comments against his only option, by people that do not use a tow dolly. I fail to understand why.
We have had an Acme EZ dolly for 3+ years now.
All welded construction and American made.
Built in Surge Disk Breaks and LED lights.
There is NOTHING else to buy or install.
Tongue weight is under 50 lbs.
Total Weight is under 400 lbs and at age 67+ I can easily roll it around.
Setup is around 10 min and we are off and running.
I took reflective tape and marked where the ramp center need to be so
when I setup they are ready.
The unit tracks well and I have to remember to check that it is there.
Simple, easy and effective.
We are pleased with it.
โJun-09-2015 07:47 PM
โJun-09-2015 04:46 PM
โJun-09-2015 04:35 PM
โJun-09-2015 03:53 PM
โMay-15-2015 11:46 AM
โMay-15-2015 11:26 AM
โMay-15-2015 05:51 AM
Jbird wrote:
Having read through this thread,I think I understand most of the advantages and disadvantages to each system. I'm considering a tow dolly but Im concerned about moving it by hand on uneven surfaces. Any advice from folks using a tow dolly would be appreciated. One post refers to 400lbs with 50 lb hitch weight. That sounds like a problem to wheel around? I know I could add a hitch to the toad, but hitch/unhitch would get to be a real session.
โMay-14-2015 04:11 PM
โMay-14-2015 01:50 PM
โMay-14-2015 01:09 PM
โMay-14-2015 05:34 AM
โMay-13-2015 07:57 PM
supercub wrote:
I'm looking at a new car, but it can't be towed 4 wheels down........so thinking of a tow dolly. I've never had one. So, I'm looking for any and all comments, pros and cons concerning the use of a tow dolly. Thanks
Brian
PS: I assume any front wheel car can be towed on a dolly, like a Ford Escape?
โMay-13-2015 06:31 PM
blknomad wrote:
I have read several of these post of people who are downing the use of tow dollies and I'm pretty sure I know what you are doing.
First, tow dollies as are trailer axels are made with a certain amount of caster and toe-in so it will self center after a turn same as a car. If your receiver is not the proper height it won't track straight.
Second, If your straps get loose, you didn't put them on properly. I may have to add a click to the strap ratchet but not often.
Third, How do you hook up your 4 down in the rain? The tow bar pins, the safety cables, the light wire, how long do you have to idle and run through the gears to oil the trans? How often do you stop to do this? Did you pull the fuse? Install brake controller? Must be Magic.
Fourth, I can back my dolly and car just as far as you can your 4 down.
Finally, DW and I can load our car and strap it less than 10min. and unload it in 2min.
If you decide to go with a tow dolly, get a good one It will be cheaper than having nice car butchered to install tow hooks and having to buy a brake controller.
Sorry I had to vent.
