โSep-10-2016 06:33 AM
โSep-10-2016 08:51 AM
โSep-10-2016 08:08 AM
footslogger wrote:
Today, Friday Sep 9, I had an incident and punctured a sidewall in Duluth MN. Currently I have Toyo 12R22.5 all around. These tires were installed in July 2010, so they have been in use for a little over 6 years. The tires were not fresh when I installed them: they ranged from 1.5 years to 0.5 years old when installed (I was misled by the dealer). Since they are almost aged out Iโm inclined to replace all 6, if I can find a suitable set. Therein lies the rub.
I called a local Class A RV dealer for a recommended tire vendor. The first could get nothing until at least Wednesday. The other could get me some Goodyear G661s in my size on Monday morning (mine is an uncommon size). The dealer said he had put this model on RVs in the past with no complaint. I looked up this model on the Goodyear site, and it is characterized as a truck tire rather than an RV tire.
So, it looks like my options are to buy one or a whole set of the GY G661 or stay here for up to a week if I choose a different model or size. I canโt really do any more until Monday. We have been on the road for over two months and need to be home in NC in a week or so, so our time is not unlimited I will do some research over the weekend for other models.
In the meantime:
1. Does anyone have any experience with the GY G661.
2. I like my Toyos, but that may not be an option. Any other recommendation for a particular model?
โSep-10-2016 07:58 AM
โSep-10-2016 07:41 AM
Ivylog wrote:
I have no idea why on a 33' coach they put 12R22.5 tires. What pressures do you run in them... 85 lbs ??? My point is a 12R22.5 is way more tire than you need for your weights. I would go to 11R22.5 tires that have 492 revs/mile instead of the 12s 487... not enough difference to worry about. You would have to increase your tire pressures by 10 psi because the 11R has a little less load carrying capacity.
A 11R is a very common truck tire (your 12R is not a RV tire) and they may even have it in Toyo or Hankook for a lot less money. I would put two 11R on the front and get back to NC. I'm running six Hankook 11R/22.5 on the back of my DP because I did not need 295/80/22.5 on the rear for my weights. I'm running 315s on the front instead of 295s.
โSep-10-2016 07:32 AM
โSep-10-2016 07:29 AM
โSep-10-2016 07:26 AM
โSep-10-2016 07:03 AM
โSep-10-2016 06:52 AM
jplante4 wrote:
I'm assuming you meant to type 12R22.5.
I had 9R22.5 on the Sahara but was having a hard time finding them. The manufacturer also recommended 25570R22.5 as well. I bought a set of 6 Yokohama RY023 tires for $2500. These are 16 ply H rated tires. The only issue is the smaller diameter makes my speedo read high.
Here's a thread on the 661s.
โSep-10-2016 06:40 AM
