โJul-09-2015 09:47 AM
โJul-11-2015 09:59 PM
โJul-10-2015 04:50 PM
golfergo wrote:
The water stays in both stools OK. So if there is a vac leak in the lines from the stools to the pump does anyone know where the access to those possible leak points are?
Also it seems if air gets in to lose vac, can liquid leak out the same place?
โJul-10-2015 04:00 PM
โJul-09-2015 10:14 PM
โJul-09-2015 06:18 PM
โJul-09-2015 04:19 PM
โJul-09-2015 11:21 AM
โJul-09-2015 11:11 AM
โJul-09-2015 10:32 AM
golfergo wrote:
The manual for my vacuum toilet in a 2013 35k Bounder says that occasional vacuum leakage is normal. After hearing the pump run every 15 minutes all night, the dealer said that was normal. How often does yours run?
There is a kit to check the system for leaks. Has anyone used this kit and how does it work?
I appreciate any advice or stories of experience with this system.
Dick G.
โJul-09-2015 10:15 AM
