vibration
vik1
Hi.
I had some vibration in the frame in first between 65 & 70 miles/h and after less.
I thought it was the balancing of the wheel.
this morning I went in a garage specialized in tires.
What he found.
I have off road tires,he did the 6 wheels balancing, changing a bad tire.
it's realy better but little vibration atoll between 65 & 70 miles/h
In France:
GMC Sierra 1500 SLE V8 5.3l 2007
Sun Valley Sun Lite 2005
In USA:
2009 Four winds Chevy 30ft
6 REPLIES 6
SoCalDesertRid1
Around here the birds like to hang out underneath my vehicles. It's shady and lots of places to hide under there.
If you're still having vibrations and your tires/wheels aren't the issue, possibly the driveshaft may be out of balance or have a worn u-joint or carrier bearing.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
vik1
Triker33 wrote:
Going 65-70 MPH in first gear is too fast. You should let the transmission up shift a couple gears. 🙂
Why you say that.
I've never say it was on first gear
In France:
In USA:
DrewE
I had some (OK, a lot) of vibration around 65-70 on my last trip. Obviously something was out of balance.
I ordered and installed a set of Centramatic balancers--quite possibly overkill, but I hope to keep the motorhome for a long time, and all the reports are they work well.
While installing them, I discovered that I had the remains of a bird (yes, a bird) smashed around the inside of the right rear inner wheel, between the wheel rim and the brakes. How it got there I have no idea; maybe it though that a nice protected spot to start building a nest or something. Probably that was the cause of the out of balance wheel.
At any rate, after cleaning it out and installing the balancers, it's much, much better...and I can look forward to continued smooth riding.
Terryallan
Also. Something else to think about. IF you are still having some vibration in the first 70 miles. "Some" tires develop a "flat" spot when setting over night, or for a few weeks, and if your MH is sitting for a while. That could be part of the problem.
Of course after they warm up the "flat" spot works out, and the vibration goes away.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Triker33
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
j-d
Good on You AND the Shop!
Hard to find a shop that knows how to solve problems. Most just want to make a big sale or make a snap judgement fix without digging into what's really going on.
Besides, unless that bad tire was made with a lump in it, that's always been there, something in there was getting ready to fly apart and it's great you caught it now.
