What 22.5 tires are good and won't break the bank?
lacofdfireman
Getting to the point where I need to replace my tires on my Motorhome. Not because of wear because they only have 33k on them but more because they are 8 years old and are starting to show some dry cracks on the sides. Also my steer tires are worn on the outside edges so I'm sure an alignment will be needed also. So right now I have 235/80 22.5 Michelin XRV's but the local tire shop wants over $500 a piece. Ouch.
So what's a good tire out there that will fit that will be a good tire. I know there has to be something out there that's not an RV specific tire that will be just as good. Tell me what your running and what they cost.
2007 Forest River Georgetown 350 DS SE Bunk Model Class A V10
2013 Yamaha Super Tenere 1200 ADV Bike
MotoJug Motorcycle Hydration System
39 REPLIES 39
lacofdfireman
Ok so you Toyo lovers what model and size did you go with? Also is there an validity in using wheel covers to prolong tire life?
jplante4
255/70R22.5 Yokohama RY023 16 ply H rated. $2500 for 6 mounted and Equaled.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
lj2654
toyos 4 years ago, very happy with them
2001 Beaver Contessa Naples 40
2012 Cadillac Srx
retired AirForce 1979-1992
Triker33
Other brands a 245/75/22.5 will have the same diameter as the 235/80's
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
Campinghoss
I just replaced my Goodyears with Toyo's and used liquid balance in all 6 of them. I am very satisfied with the ride and handling. My price was 1950.00 for 6 tires mounted and 125.00 for the 6 qts of liquid balance.
Camping Hoss
2017 Open Range 3X 388RKS
MorRyde IS with disc brakes
2017 F-350 6.7 with hips 8'bed
Lucie our fur baby
Lucky 9/15/2007 - 1/30/2023
MrWizard
Moderator
Moderator
jergeod wrote:
I replaced Mich with Toyo all 6 mounted balanced out the door $2200 two years ago. Great tires nice ride.
you did better than me
i just had 4 Toyo's for the rear in Jan, $1785 including $330 per tire . $55 per mounting, tire beads and taxes
OUCH !
$945 for the two fronts in 2014
i need to find another place "next time" in 2023
I can explain it to you.
1997 F53 Bounder 36s
Pangaea_Ron
I had to replace my Honda CR-V tires in St George a couple of years ago, and had great service and price at Gene's OK Tire there. My braking system failed and the Honda stopped the MH from 60-0 in about 200 feet, and squared off the tires.
I usually use Les Schwab Tires due to their service, but they were not available in St George. Gene's tires were about $40 per tire cheaper that Les Schwab would have been.
I just replaced my (6) 235/80 22.5 Michelin XRV's due to checking and age rather than tread wear. I paid $400 per tire for Toyo's at Les Schwab. They were the cheapest reasonable tires that I could find.
2008 Itasca SunCruiser 35L
2014 Honda AWD CR-V EX-L
Kayteg1
Befriend tire shop people.
It was few years ago when I needed 8 tires, so I bought 2 new Michelins for front and I bought used for rears at $100 a piece for Michelin with about 20% of thread. They were 2 years old at the time and now at 10 years are due for replacement, still with lot of thread.
jergeod
George & Jerri
USMC VET
Jayco Eagle 339 flqs
upstate NY
dbates
I replace my Michelin with Hankook 225/7OR19.5 in July 2013 because of the price difference and the many good comments about the Hankooks on this forum.
I've now got 12,520 miles on them and they seem to be doing quite fine.
Dave
Plus New Brunswick, Prince Edward Island & Nova Scotia
