What did you do to your Class A MH today???
Rich_Panganiban
This is always a fun thread to watch, so I thought I would start one here.
2007 Jayco Greyhawk - Kodiak 32SS
'00 Subaru Outback Wagon
5,655 REPLIES 5,655
RayChez
Bigdog wrote:
Drove back from the NW RV.net mini rally at Point Hudson Marina and RV park in Port Townsend,Wa. where I was the wagonmaster. Got it all cleaned up and ready to load for our trip next week to Hood Canal for for the daughter's wedding at Alderbrook Inn.We're staying at a neat waterfront rv park next door,the Robin Hood Cottages and rv park. When I got home I discovered that the new right taillight assembly had arrived,they had installed two left side ones,and got that installed as well as putting on my new CAT decal with Sylvester the cat on it..It's cool and they come from a lady on the CAT forum over on IRV2.
Yea! I saw a decal next to where you put fuel on a coach and it said Cat Food. I thought it was cute.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar 3126-E
3000 Allison Transmission
Neway Freightliner chassis
2017 Buick Envision
Bigdog
GO COUGARS
2001 Tradewinds 7390 LTC
330 Cat Turbo Freightliner Chassis
2011 Jeep Liberty(toad)
'88 Mustang 5 Spd 5.0L GT convertible (not Toad)
Treefrog
Fiberglassed a tree branch souvenir hole in the cowling that allows the heat to rise from the reefer.
2000 Country Coach Intrigue 36' 350 Cummins ISC
2015 Lincoln MKX
FMCA 351235
Look for us at Civil War Reenactments and the SCA.
RayChez
Today I waxed the fiberglass roof with Blue Coral wax. I needed to get that carnauba wax that is in the Blue Coral so that it protects the fiberglass roof from the UV rays.
Next job will be to crawl under the coach and lubricate all the fittings and change the filter and engine oil.
I am eventually going to change all the fluids like drain the anti freeze and add some new stuff. I also want to change the air dryer filter. Not sure if I can do that myself. It looks like a hard job.
2017 Buick Envision
WESIII
Removed batteries cleaned compartment, painted battery hold down bracket, checked fluid level topped off with distilled water and reinstalled. Whew!!!
SpursMVP
Finished the transmission fluid/filter change. We are upgrading to the Transynd 295 synthetic fluide so my wallet is still hurting from the cost of the fluid.
Also checked the differential fluid level and added 1 qt of Lucas synthetic fluid. Looks like we have a leak around the rear streetside leveler, but its still maintaining pressure and holding the coach.
All of this is in preparation for our trip to Lincoln, NE for the season opener of the Husker football season!
2001 HR Endeavor
330 HP Cummins ISC
2006 Jeep Wrangler
BrucePerry
Replaced the remote wire from the inverter to the overhead control panel. Wasnt as easy as I thought it would be, but learned some more about how my rv is constructed ๐Ÿ˜‰
GHOST1750
Picked it up from the CAT shop and put it back in storage for a couple weeks, Then off we go again.
Just Don and a Chiuahua called Dulce
2003 39' Tradewinds LE
2002 Cavalier tow
Korean Veteran, USAF
FMCA F357981
CC4C
GOOD SAM
Life is a journey, not a destination !
blevtr
Repaired the damages from last weekend's trip. The dog punched holes in the screendoor, replaced the screen. The handle on the antenna stripped (when the wife raises the antenna, which she never does, and then I pop in and raise the already raised antenna, the handle strips. Come to find Weinguard did a nice design job, so I just had to file off the rough spots and tighten the setscrew. The generator decided not to start using the inside control, not a problem 'cause we had electric this time. I just went thru and cleaned and tightened every ground I could reach, all better now. When in doubt, check the ground.
wandering1
nothing, what did you do?:S
HR
wolfman01
Idled engine to exercise it and recharge chassis battery. Inadvertently overfilled reservoir for jacks (oops). Relevelled coach.
2011 Hyundai Accent SE (8k)
1996 Tiffin Allegro Bay 31' ga$$er motorhome (42k)
Bear, my four legged, furry companion.
RVing is an obsession more expensive than drugs. :E
SRT
Hand waxed the top half of the rear cap (gel coat). It did get a little bit shinier, but still has streaks/blotches. Guess I'll have to use the orbital buffer to apply the wax for a second coat. Then I can put the scaffolding away to do the lower half.
ctpres
Dug a BIG hole in the ground under the old travel trailer cover (is on small hill) so I can park SKI-ONE/our RV under it. Went down two feet, next I add about six inch base of washout or crushed concrete. Phase two is connector to existing driveway and phase three extending roof to fit coach. All part of hidden/unexpected cost of owning class A and we love it. BTW SKI-one "spending kids inheritance" number one- SKI-TWO is Jeep.
A "Retired" Mind is a Terrible Thing to Waste
Chuck USNR, USAF & USCGA and Suzie
Challenger Owners Club
2015 Thor Challenger 37KT
2014 Ford Fiesta
2011 Sea Eagle 385 FT kayak
2009 Polaris RZR
2014 Zenetto Stealth road bike
Canadian_Rainbi
Added some weather stripping around the base of the bed--had found tons of dust gets in that way when traveling on gravel roads! Esp Top Of The World Alaska to Yukon!
sd1209
Took the cover off, conditioned the rubber roof and washed the MH..Looks brand new.....
Installed an Ultra Guard mud/rock flap on the rear...Easy job that took 3x as long as expected, which is normal....Had to attach to the frame.....Looks good tho, perhaps it will save a rock or two from hitting the dingy....
Steve and Liz
Fallbrook, Ca
Steve and Liz
Elko, Nv and San Diego, Ca
2017 Lance 1172
2016 F350 dually
2010 Jeep Wrangler
