What is the best water pressure coming into the RV?
thestarfinder
What is the safest water pressure(on the high side) coming into the RV?
I don't want to pop any water lines,but I want good pressure.....
Thanks in advance,Tom
Exist Responsibly.........
18 REPLIES 18
Bob___Ann
We run 50-55 Pounds on ours as that is needed for the tankless water heater. We regulate it through a Watt water regulator.
Bob and Ann
Schnauzer - Della (Rainbow B 3/31/17)
Chihuahua - Lola (Rainbow B 12/26/18)
Autumn-Red Poodle
2019 Tiffin 40 IP Bus
Powerglide Chassis
Cummins 450
Onan 10,000 Watt
Four Slide/ 1.5 Bath
2021 Jeep Unlimited Sahara Toad
Demco Dominator & Airforce One
paulcardoza
I have my WATTS set @ 65psi
Paul & Sandra
Plymouth, MA
2014 Heartland Cyclone 4100 King
Sturgeon-Phish
We opened up our camper this weekend and hooked up the water with an inline regulator. After flushing the water system, I started working on something eles and the outside shower faucet handle blow off the faucet. Luckly I had the door open from flushing and no water entered the unit. I figure the regulator went bad,and I have no idea what my supply pressure was. Not many people were at camp and I'd say the pressure was pretty high. In hindsight the pressure when flushing was higher than normal. I'm replacing the regulator with one that has a gauge.
Live and learn or read forums and learn from others!
Jim
2003 GMC 3500 crew dually. Transfer Flow 50g aux tank; ISSPRO gauges, PPE boost valve, air box mods, stock exhaust w/o muffler, Line-X, Pace Edwards bed locker power tonneau. B&W Companion. Pulls a '05 Wildcat 31QBH 5th wheel
thestarfinder
Thanks for all the great responses! I will try different pressures and go from there...Thanks again,Tom:C
HHg_in_Austin
I use an adjustable Watts-285 regulator, and keep it set at 52psi. Gives me great pressure with super flow !!
Hhg
HHg in Austin
2013 Tiffin Phaeton 40-QBH
2018 Chevrolet Tahoe Toad
bluwtr49
I changed my internal regulator from 45 psig to 60 psig and it works much better.
Inlet with regulator
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
wa8yxm
My RV says "45PSI max" but I think Im feeding it 49 (As close to 50 as I can get with the gauge I am using) Generally, from what I am told, PEX can take whatever you feed it (Within reason, 120 NOT a problem) but sometimes the fittings get a bit....anemic.
But some of the valves used in RV's start blowing up around 60 PSI. so 45-50 is what I consider the safe range.
debandi
We use a household water pressure regulator screwed onto the faucet and factory set at 50PSI. No problems. And its big enough so we don't forget it when we disconnect to leave the campground.
John Spear RMCS(SW)USN RET '88
Debra is my 'nagagator'! She tells me where to go.
Enjoying our 2006 Roadtrek Adventurs RS
Clay_L
I have had my Watts whole house regulator set to 65 psi for ten years. I have spent three summers where the unregulated pressure was 140 psi so my plumbing and fixtures have seen extended periods of time at 65 psi.
Early on I replaced the kitchen and bathroom faucets with residential units that are rated to 85 psi. The shower is still the original RV type and still works fine.
Clay (WA5NMR), Lee (Wife), Katie & Kelli (cats) Salli (dog).
Fixed domicile after 1 year of snowbirding and eleven years Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
RoyB
We usually use our fresh water tank and own water pump when setup. The city water connections always are different everywhere we end up.. I know what the pressure is using my own water pump... Since we camp alot off the power grid always nice to know if the fresh water tank and pump is working good anyway.
I hookup a water hose with spigot to the city water connection and hang the spigot on the front deck railing. Great for squirting squirrels.. Easy to fill up fresh water tank with spigot.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Old-Biscuit
I use an adjustable Watts Regulator on city water supply.
It is set at 50# static
WayneLee
The highest pressure is dependent upon many factors including type, manufacturer, age, type of construction, etc. When I purchased my current coach, I contacted Monaco with this question. I was told that, at that time, Monaco was testing each coach during the final assembly, and each coach must pass a pressure test of 100 psi. On the other hand, Monaco also advised me to keep my water pressure at 50 psi or lower because the "weak link" in the system would be the incoming water hose.
Wayne Lee
Out West Somewhere
2016 Forest River Sunseeker 3050DS Class C | Hummer H3 dinghy
cochise49
I too sometimes turn on the pump when taking a shower or using the kitchen faucet sprayer. The parks utilities are my first choice over our own resources but, water pressure can vary. Like to use the electric heating equipment when available.
Bev& Keith
2014 Winnebago Adventurer 38Q
2013 Honda CRV, Roadmaster Falcon AT, Invisibrake
Puttin
Mfar1234 wrote:
to be safe....40 - 45
I'm at 42 and am happy with it, things will last longer too.
