What kind of Animal would do this?
bagomike
While cleaning and checking roof air conds. I ran across this. there was roofing nails, wire connectors zip ties, and small sticks, between the condenser and the fan blade. Some one replaced the roof air rather then clean it, or they didn't look
9 REPLIES 9
Cousin_Eddie93
Eliminate the threat immediately. I had a squirrel family take up residence under my engine cover several years ago. The little f*****s chewed away all my vacuum lines,many wires, injector casings and throttle linkage of which Had to fabricate myself since ford stopped making the parts years ago.
Use critter ridder, shotgun shells, dynamite, whatever it takes.
bukhrn
Pack Rat, Squirrel/Chipmunk, birds
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
SoCalDesertRid1
Pack rats. They will pick up and carry just about anything they can into their nest. They're very strong and determined little buggers. Never underestimate them.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
edatlanta
I don't have a picture, but I noticed a big nest a few weeks back on top of my left slide. I have awnings over the slides and this nest was big with large pieces of sticks, etc. much larger than a bird. It was a squirrel nest. Solution: Tools required
Step ladder
Stihl gas powered blower
Procedure:
Set ladder at rear of slide
Start blower and let it warm up
Climb ladder and aim blower into area under the slide awning
Full power on the gas engine
The Fun:
Watching the nest and the squirrel blow out the other end and the squirrel running like crazy for the nearest tree after a 11' drop to the ground.
Preventive:
Stihl chain saw and removed the entrance and exit ramp limb(s) from the nearest tree to the rear of my rig.
Problem solved.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
Gale_Hawkins
Never seen that but have had dirt dabbers lock up the A/C motor. At first I thought it had seized but with a wrench going back and forth I was able to crush the nest(s) and it has not happened for the past 9 years.
Must have been a large hole in the A/C housing to bring all of that through especially for a bird.
gwwing2
I think I had a mechanic do that... once 😉
Olddud
That could be a wren nest.
rv2go
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
darsben1
Holy **** that is a lot of junk.
A real nest.
Traveling with my best friend, my wife in a 1990 Southwind
