Which battery runs what???
Deni
We just bought our first RV....a 1996 Tioga Montara. We can't find anything that tells us which battery under the truck hood runs what. There is one on the left side of the engine...and one on the right. Is there any way to know which is which?
12 REPLIES 12
Bordercollie
I think that passenger side battery was usually the house/auxiliary battery in that era. Our 79 Chevy Delta Class C had that setup.
pnichols
j-d,
Are you sure that's a "true" deep cycle RV battery in your photo above?
I rotated and blowed up the image ... and I see the word "Cranking" ... which is probably part of the spec phrase "Cranking Amps".
True deep cycle batteries may not list cranking amps ... and if they do, what's the purpose of even mentioning this performance criteria for use in deep-cycle-only applications?
Here's a partial side shot of the battery in your photo above ... note that the phrase "Marine/Deep Cycle RV" is printed on the side of the battery down near the bottom ... which means that the battery is not a true deep cycle battery manufactured solely for optimum deep-cycle-only type service:
2005 E450 Itasca 24V Class C
j-d
Pic of an RV Deep Cycle "House/Coach" battery. Notice the "RV" designation on the label, and the 3/8" stud terminals in addition to the typical battery posts used on "Chassis" batteries.
j-d
mikhen wrote:
House battery should be marked deep cycle, if it's still readable.
That's what I was thinking, too. One battery serving as
Chassis/Engine/Star/Crank (people call same thing different names) and it should be your typical Automotive Battery. If you can read the label, words like "Cranking Amps, Amps at X Degrees" etc.
The other serving as
Coach/House/Accessory (terminology again) and it's basically a "Trolling Motor Battery" if you're asking for one at a place like Walmart (which I recommend, by the way - good batteries at decent price available nearly everywhere nearly 24 hours a day 7 days a week). And it should be labeled "Marine Deep Cycle, Trolling" etc. With an Amp-Hour rating and probably include terminals for nuts or wingnuts in addition to the traditional Battery Posts.
Just had to be dure it wasn't diesel
mikhen
IAMICHABOD
On Fleetwood Tioga RVs with two batteries under the hood. Chassis battery is on the drivers side and house battery is on passengers side
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
Deni
Thank you donn0128! I should have thought of that!!
Deni
No...it's a gasoline engine.
CharlesinGA
Two batteries under the hood does sound like a diesel. Does it have the 7.3L Powerstroke diesel? If so, the two batteries are wired together in parallel and act like one large battery.
You should have separate batteries for the coach, somewhere else.
Charles
'03 Ram 2500 CTD, 5.9HO six speed, PacBrake Exh Brake, std cab, long bed, Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
pianotuna
Nomad III
Nomad III
Hi Deni,
Is it a diesel engine?
Welcome to the forums!
Regards, Don
donn0128
Actually its pretty simple. First look for identificstion. Second remove the ground csble from one and see what does not work. Third, the batyeries will lead to an isolator, so you can check thst.
2oldman
Totally guessing.. but they both may be for the engine, connected in parallel. Check the wiring. I always thought coach batteries were in the coach part.. somewhere, like under the steps.
