โJan-06-2015 03:25 PM
โJan-08-2015 09:02 AM
This is my first winter with an RV. I live in Cleveland Ohio and right now it's 12 degrees. My rig is in an indoor heated storage facility and I didn't winterize. I'm going to Florida in February with stops in Cincinnati, Chattanooga, Tallahassee, and then on to Naples. I'll be returning to Cleveland and cold temperatures again at the end of February.
I haven't drained my water system.Why can't I just add anti-freeze, and then just flush that out when I get to warmer weather? Then on the way back, just add anti-freeze again?
Why does the system have to be drained first?Thanks for any help that you can provide.Ken
โJan-08-2015 08:47 AM
Oldme wrote:
So everyone here goes by the "what if" fear rule.
I do not see it. I gave up living fear long ago.
His RV, like mine is a Class C.
Fresh water tank will be inside.
Fresh water lines will be inside.
Empty or near empty gray and black are outside.
Recommended some pink antifreeze in my first reply.
Storage is heated.
I guess a power outage for days is a possibility.
Without his knowledge for days? Maybe.
Driving - inside the Class C will be heated, so
the fresh water line and tank will be above 32*.
If for some reason temps drop below 32* what little
water that is on the fresh water line will take hours to freeze.
Non pressurized lines with open faucets will give any remaining
waters plenty of room to expand if it did somehow drop that low
inside coach while driving.
To each his own.
Mine stayed outside in 6* weather for 2 days with the heat set on
the lowest setting and Pink stuff in the traps and tank.
Never in the lines.
Was I lucky? Maybe.
Nothing freezes above 32* and the inside does not get that low.
The OP can real all the replies and make his decision.
Lots of opinions.
1-8-2015 FYI ...
It got down to 11* last night here.
RV is in the driveway just as I said above.
It was 50*+ inside.
I check it daily. No problems.
โJan-08-2015 06:25 AM
โJan-07-2015 03:57 PM
โJan-07-2015 02:08 PM
โJan-07-2015 09:50 AM
tenbear wrote:wolfe10 wrote:
Oldme,
No, did not miss that. But, depending on how his coach is configured (where tanks are located-- how insulated they are) AND how cold it is for the first couple of days on the road, THAT will determine whether he needs to winterize.
X2 That time of year his first 2 stops can be cold. A lot depends on his rig. I wouldn't tell him he will be ok, then he hits a cold spell and damages his rig.
โJan-07-2015 09:19 AM
wolfe10 wrote:
Oldme,
โJan-07-2015 08:01 AM
โJan-07-2015 07:53 AM
โJan-07-2015 04:19 AM
โJan-07-2015 03:32 AM
โJan-06-2015 06:26 PM
โJan-06-2015 05:30 PM
โJan-06-2015 04:31 PM
