Apr-26-2013 10:44 AM
May-10-2013 06:42 PM
May-10-2013 04:21 PM
Arizona Kid wrote:
I don't think a Honda 1000 will run your AC. On those type of units the start up power needed is usually double the BTU's. So an 800 BTU AC will require 1600 watts of start power. I would also suggest the Honda 2000.
May-10-2013 04:11 PM
stan909 wrote:
Re shock absorbers. I think Bilstiens or Konis for RV use but seriously I think some put rubber around the opening or make a shelf with rubber for the AC to sit on. Low watt ACs are only around a hundred bucks so maybe it doesn't matter to you.like you. I bought my lil B to use without having to take the Bounder out and feel much more freedom. I am also trying to weane the wife away from the bigger rig for when we ritire and travel more. Thanks for your posts.
May-10-2013 02:44 PM
May-10-2013 02:07 PM
May-10-2013 01:13 PM
May-10-2013 09:02 AM
May-10-2013 07:54 AM
May-10-2013 07:24 AM
sizzy wrote:
What kind of inverter do you have? I don't really understand them but would like to be able to use the microwave.
May-10-2013 06:27 AM
May-10-2013 03:47 AM
May-09-2013 08:33 PM
BillMFl wrote:
Window AC project now complete
Click on pic to enlarge
(snip)The dreaded hot humid nights are no longer an issue. 🙂
May-09-2013 04:36 PM
May-09-2013 02:50 PM
