window fan
prstlk
Have been searching the net for a small fan that would fit inside the "standard" 20X52 MH, 5 ver, rv rig window frame. We don't need a roaring fan,just something to move some air.
07 HR ambassador
as always thanks to all!
JW
2007 Keystone Challenger 5th wheel, Ford F350 Super Duty 6.7L Diesel, Short Bed, 2 dogs and the cat and rolling down the road full time since May 2014
7 REPLIES 7
BillMFl
The small window fan I have is easy to set up. But I only use it when the coach has been closed up for a while and is very hot and stuffy. My two Fantastic fans plus the window fan quickly pull the heat out. Then the roof acs can do the rest much faster after the really hot air is gone. Or if the outside ambient temp has dropped nicely I will just run the Fantastic fans on low with a couple windows open and enjoy the fresh air. I'm a light sleeper and the roof airs are a bit too noisy for me so at night I only run the ac located in the front of the coach. Fans vs ac totally depends on what states or climates I'm in. For example, up in Maine I rarely run the ac's at all and we often use a small electric heater at night even in the middle of summer. Night time temps in the 50's are typical right on the coast where we stay. Traveling thru states like Florida and Georgia the ac's get a workout day or night.
Order is illusion. Chaos is reality. But right or wrong I'm still the captain. 🙂
AllegroD
Bigdog wrote:
Empty Nest, Soon wrote:
Fantastic Fan in a ceiling vent will move plenty of air. Can't beat it.
Wayne
X2. the one in my reading room pulls enuff air out that it'll hold the door closed if it's on high and you don't want to hold the flush valve open if it's on either.
x3 Turn FF on high exhaust in the back and open 1-2 windows in the front and create a breeze through the RV.
If you do not have or waant to go through an install of the FF, the small 2 fan window fan mentioned above might work. Ya gotta figure out how to set it up.
Bigdog
Wayne
GO COUGARS
2001 Tradewinds 7390 LTC
330 Cat Turbo Freightliner Chassis
2011 Jeep Liberty(toad)
'88 Mustang 5 Spd 5.0L GT convertible (not Toad)
Empty_Nest__Soo
Wayne
Wayne & Michelle
1997 Safari Sahara 3540
BillMFl
I bought a small unit at Target of all places that has two fans side by side and is only about 8" high by about 20" wide. And it has flexible side wings to adjust the width wider. It can mount horizontal or vertical and has high/low speeds. You can flip it for exhaust or intake. I use it to draw in cool air faster while the ceiling fan is on exhaust.
msturtz
I had really good results with my ceiling exhaust fan. Open the window you want air to com in and turn on your exhaust fan.
FMCA member
BTPO1
Just wondering if all you want to do is move some air can't you just open the window and turn on the ceiling vent fan in the exhaust position to draw air in?
Jack
2003 Rexhall Vision 27'
2019 Chevrolet Equinox
States we have been to with this MH
