Air Force Navy Lodging "availability" websites are "unsafe"?
navybanker
Searching the internet looking for military temporary housing facilities and attempting to check availability on dates for specific bases getting "unsafe" site on both Google and Edge! I am not able to check online. What goes here?
2017 Montana 3611 RL
2012 Chevy 2500HD Duramax
12 REPLIES 12
TurnThePage
Belgique wrote:
A lot of DoD sites will do that. I just ignore it.
But to ignore it, you usually have to jump through hoops. Be prepared to do so if necessary.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
Belgique
Hickory, NC
2007 Fleetwood Discovery 40X
1492
Moderator
Moderator
magicbus wrote:
I just read that Google will now label any site that does not use httpS as "unsafe" in a bid to force site owners to adopt SSL. I just tried WWW.DODLODGING.NET and it worked fine from Firefox (producing http://www.dodlodging.net/ with no S).
Dave
This is also why I believe you received a browser unsafe warning.
A couple of security scans returned a safe site, not blacklisted by any of the major security sites. It also appears the site is hosted on Amazon AWS in Ashburn, VA.
enblethen
Some bases have switched to "privatized" lodging. the website are through the contractor.
The prices for many have gone up to as much as off base.
You can search for what base and try going that way,.
In the Trailer life directory is some military listings
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Optimistic_Para
I run Firefox, and I get this message every once in a while. Always from a site I use regularly, and if I go back a couple hours later, I don't get it.
I've decided it's just the net having a temporary nervous breakdown. Or Gremlins!
navybanker
I tried navy-lodge for Corpus Christi and could have made a reservation! Must be an AF thing!
magicbus
Dave
Current: 2018 Winnebago Era A
Previous: Selene 49 Trawler
Previous: Country Coach Allure 36
1995brave
I use IE and Https://www.navy-lodge.com when I look for rooms at CCNAS Lodge in Corpus. Just checked and it is still fine.
navybanker
I searched for "Air Force Inns" and was at the main site. I looked in the "directory" on the site for Peterson AFB and clicked on it. I clicked on "check availability" and the message came up. I have had the same luck with Navy Inns. In the past on Navy campgrounds site have gotten the same result. I called the Navy number and got a real person and made reservations. We are thinking about attending a wedding in July and want to check availability before planning the auto trip.
WWW.DODLODGING.NET
kerrlakeRoo
It looks like they didn't renew the security certificate in time.
SAR_Tracker
try taking the "s" off the "https://" in the address.
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
enblethen
What website are you trying to use?
Bud
USAF Retired
Pace Arrow
