โSep-08-2014 10:28 PM
โSep-09-2014 05:58 PM
buzzard616 wrote:Thanks for the warning. YES, I am pleased with my ScanGuage II. I can see the actual water temp and tranny temp. :B
Lesson learned - I suppose there's a reason folks recommend the ScanGuage and not this thing. :S
Stu
Reese Dual Cam Straight Line HP Sway Control
โSep-09-2014 12:55 PM
ChopperBill wrote:
I don't check milage anymore. It is what it is.
โSep-09-2014 08:26 AM
โSep-09-2014 06:46 AM
โSep-09-2014 06:23 AM
โSep-09-2014 06:13 AM
buzzard616 wrote:
My signature TV is a 'Work tuck'. No fancy trim, rubber floors, etc. and no computerized driver information display. Trying to get mileage figures I used the gadget shown here to connect with an app on my tablet.
It worked fairly well but what it also did on two separate occasions was to throw the ECM in the truck into a coma. The biggest PITA was the transmission refused to come out of 1st gear. Had to stop; shut down; disconnect the battery; put it all back together and start again. After the 2nd time I suspected the wiz-bang gadget and pulled it. Hasn't happened since.
Stu
โSep-09-2014 06:12 AM
poncho62 wrote:
Try something I have been doing for 40 years, and much more accurate. Use the odometer, the gallons on the gas pump and a calculator.....In the old days, I even was able to do it without the calculator
โSep-09-2014 03:28 AM
โSep-09-2014 03:19 AM
โSep-09-2014 02:28 AM
โSep-08-2014 10:59 PM
buzzard616 wrote:
With no 'preview' option here the only way to proof read and edit a post is to post it first and then use the 'edit' function.
โSep-08-2014 10:47 PM
TucsonJim wrote:
Not sure what the purpose of you post is???
โSep-08-2014 10:30 PM
