โOct-28-2015 01:00 PM
โOct-30-2015 03:26 PM
SparkDr wrote:
Devil's advocate question here. If you have an app such as DishPointer AR and are boondocking in an area without cell service, will the app still work?
โOct-30-2015 01:05 PM
CacheClone wrote:I guess all systems are different, but on my DTV HD-DVR box I don't even see the 110 or 119. It's 101, 99, and 103.
The numbers on the display panel of the control box inside the camper are locations in the sky (101, 110 and 119 west longitude) rather than satellite numbers. I shouldn't concern myself too much with 110 and 119, since these are alternates that won't do much for me.
โOct-30-2015 12:57 PM
โOct-30-2015 12:50 PM
โOct-30-2015 12:33 PM
โOct-30-2015 11:39 AM
โOct-29-2015 06:17 PM
Pirate wrote:20 degrees sounds about right. The dish is designed so that the reflected sat signal is concentrated on the LNB.
I have been told the true angle of satellite view to the dish is not the same as eyeballing it. Apparently the angle is 20deg upwards or something like that.
โOct-29-2015 05:28 PM
โOct-29-2015 04:26 PM
โOct-29-2015 08:53 AM
โOct-29-2015 08:16 AM
Seneca 35GS wrote:Excellent method for finding a single SD bird. Place the dish on the ground - no need to level, point it to the left of other dishes or east and set the elevation to the last elevation. There is no need to use a new elevation unless you have traveled a considerable distance north/south. Rotate the dish clockwise until the $25 signal meter at maximum gain finds a bird and then do a rough aiming using the meter. If there is no receiver signal then it's the wrong bird so rotate some more. Lock in the signal.
You guy's get way to technical. When I pull into a park I just look where the other RV's have their Direct Dish pointed and then I park accordingly, keeping away from trees. Work's every time.
โOct-29-2015 08:05 AM
brirene wrote:If you are referring to the picture in my post then yes that was on my former iphone. The app is also available for android phones. It is pricey at $20 but works very well.
Looks like the other one is for iphones? You can pick the system you're looking for, point southwest, there's your satellites.
โOct-29-2015 12:01 AM
โOct-28-2015 06:24 PM
Acampingwewillgo wrote:
.......gizmo's ...dealie-bob... ๐
