Help! New led lights don't work
DC_MC
Replaced 4 small flush mount lights over sink. Bought led bulbs. They stay on really dim all the time. Switch won't turn them on or off. Dimmer switch does nothing either
2006 Mandalay 40E motorcoach
2017 Ram PU
2017 Harley Road King
Home base Yuma AZ
14 REPLIES 14
docj
DC&MC wrote:
Would we be able to use a dimmer from Lowes that says LED compatibles, or are our RV 12v lights diff?
The dimmers at Lowes and HD are for 120V AC circuits. However, there are plenty available for 12V LEDs but you're not going to find many at your local stores. You do have to make sure that the LEDs you are working with are dimmable. Not all are.
You can find some examples of 12V LED dimmers by following this link. I've had multiple dealings with this vendor and have been very pleased. SuperbrightLEDs.com
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/braking system
WiFiRanger Ambassador/RVParkReviews administrator
Follow our adventures on Facebook at Weiss Travels
DC_MC
2017 Ram PU
Home base Yuma AZ
GordonThree
The physics of how an LED operates makes it incompatible with most incandescent dimmers. Even those that do appear to work are only giving you a narrow range of dimming compared to the incandescent bulb that was replaced.
High end RVs that use digital dimmers (the kind with a wireless or wired remote) will dim an LED better, because they're using PWM technology versus a simple rheostat. PWM uses an electronic switch to turn the light on and off really fast, such that it looks like a steady glow to our eyes. The more off than on, the dimmer the light.
Wireless LED dimmers
Ivylog
I use the same Dimmer as the halogens that I replaced with the cheap China LEDs without any problems.
Upgraded with a 08 HR Navigator 45’...
RoyB
I've never used one before but there are many listed on GOOGLE SEARCH
LED DIMMERs
Mouse click on the image for more info...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
WyoTraveler
They won't work with a dimmer switch. I have a dimmer switch over my driver position in our MH. LED just glows. I had to remove it. Like a previous post mentions try it in a regular socket somewhere else.
TakingThe5th
DC&MC wrote:
It was the dimmer. We changed it to an on/off switch and it's fine. We can get a dimmer for led's ??
Some LED bulbs are dimmable, others are not. Then there is the switch ...
TakingThe5th - Chicago, Western Suburbs
'05 Ford F350 Crew 6.0 DRW Bulletproofed. Pullrite Super 5th 18K 2100 hitch.
'13 Keystone Cougar 333MKS, Maxxfan 7500, Progressive EMS-HW50C, Grey Water System.
DC_MC
2017 Ram PU
Home base Yuma AZ
2oldman
dimmer switch
tenbear
Don't just believe the color code of the wires, incandescent bulbs don't care about the polarity so often the builder didn't care either.
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
Bill_Satellite
My guess is that it is the dimmer. Most LED's will not function with this kind of a device in line.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
RoyB
I see you mentioned a dimmer switch setup. If this dimmer was for your incandescent automotive type bulbs I don't think it will work on LED LIGHTS... LED lights take a different type of DIMMER system to make them work then the Incandescent automotive type bulbs use.
Lets hope the reverse wires is the problem but in my case here if the wires were reversed I did not get any LED operations at all...
Roy Ken
Roy - Carolyn
Admin
Moderator
Moderator
Some will do that when they are reversed.
Reverse the wires
Admin
Admin
RV.net
Ivylog
Check the polarity but when reversed they usually do not work at all. Try one somewhere else
Type a product name
