โDec-14-2013 02:10 PM
โDec-20-2013 04:33 PM
PawPaw_n_Gram wrote:nazpaz wrote:
There's a function in Streets and Trips that I use. It's called "drivetime zone."
I've been using S&T for years - and never noticed or used the function. Been playing with it for a couple hours.
Thanks so much !!!!
That's what I get for not RTFM.
โDec-20-2013 02:44 PM
drsolo wrote:wingsfan20 wrote:
AAA online triptik works very well also if you click to show campgrounds. Use it all the time.
I use Allstays (paid $ version), computer and app. It is ok. I would like a better (and permanent) filter.
โDec-15-2013 02:15 PM
Thanks so much !!!!
โDec-15-2013 01:50 PM
โDec-15-2013 12:16 PM
โDec-15-2013 07:25 AM
โDec-15-2013 05:53 AM
nazpaz wrote:
I use lots of different resources, mostly because I haven't found one that does all I want.
Also, I'll mention that, as Matt suggests, I like planning our adventures especially on cold winter nights when I have nothing else to do.
โDec-14-2013 08:53 PM
โDec-14-2013 07:54 PM
Bill.Satellite wrote:
So do I understand that you use this program to figure out where you want to go and then enter it into a different navigation program to figure out how to get where you want to go?
โDec-14-2013 07:11 PM
โDec-14-2013 06:59 PM
โDec-14-2013 06:53 PM
โDec-14-2013 06:51 PM
โDec-14-2013 06:47 PM
CloudDriver wrote:
The problem I see with using radius around a point is that it gives you a straight line, as the crow flies distance. The actual driving distance will always be longer than this and may be significantly longer. I assume you account for this by using a mapping program to give you the actual driving distance.
