Laptop Battery
Gonecamping444
Hi,I have a HP laptop that's a couple years old & lately when I plug it in to charge it or just plug it in so I don't run the battery down the screen goes dimmer instead of brighter,Before it allways got brighter when I plugged it in.Anybody know what the problem might be?The battery seems to last just as long not plugged in as it allways has,Don't get it.Thanks
9 REPLIES 9
trb46
Campfire Time wrote:
I usually buy replacements from Amazon. Don't buy the cheapest ones, but don't buy the factory brand replacement either. Go somewhere in the middle and check the reviews.
X2. I've purchased several replacement batteries through Amazon.com, and all have worked perfectly.
2011 Four Winds 23A
Only 48 more states to visit!
dons2346
wa8yxm wrote:
By the way,, You have at best a year left on that battery..........
Hog wash. I am on a HP computer right now that is still using the 5 year old battery
Gonecamping444
Thanks again for your info
Campfire_Time
They slowly start to lose life after about 3 years. Typically, if cared for properly, you can get 4-5 years out of a battery, depending on the original quality. Leaving it plugged in all the time does not diminish the life of the battery.
When the battery is new, give a full charge, then run it down to dead 4-6 times. After that you can plug it in when ever you want.
Chuck D.
โ€œAdventure is just bad planning.โ€ - Roald Amundsen
2013 Jayco X20E Hybrid
2016 Chevy Silverado Crew Cab Z71 LTZ2
2008 GMC Sierra SLE1 Crew Cab Z71 (traded)
wa8yxm
Batteries Plus is where I go for laptop batteries.. Generally the best deal, but do check it out.
Gonecamping444
Thanks, you's are right,I went into the power management center & slide the brightness over to brighter & that did the job.Some how it got moved way over,Thanks again
icanon
Chris Bryant wrote:
It sounds to me like the power management settings have been changed- not sure about what ever OS you are using, but most have separate settings for screen brightness (among other things) while on battery or utility power.
X2
Loving wife and 2 beautiful daughters.
Chocolate Lab, Lily
2014 Dodge Ram Laramie Hemi 5.7 with 3.92
2014 Dutchmen Kodiak 290BHSL
ProPride 3P Hitch
Progressive Industries EMS-PT30C
Love my Weber Q1200
Me a Happy man on retirement!!!
Chris_Bryant
-- Chris Bryant
RoyB
Most likely the main battery needs replaced. It is constantly being charged when plugged into 120VAC and only will last so long.
A new battery will cost around $50 from AMAZON...
I suspect you are flirting with loosing all your data, programs, and operating system...
Remove the battery and get the part number off of it and check on AMAZON for the source of a new one. I would stop using the computer until you determine the status of the battery.
Just my thoughts here...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
