Portable Satellite Cable Storage..ideas??
DD716TED
For several years now I have been using the Winegard Carryout antenna for Directv... I have attached 2 (50 ft) RG-6 cables along with the power cord to it.. I the past I have just coiled up the wires in about a 3 ft circle when storing them and antenna but am looking for a better / easier / smaller way to do it.. Question.. Will wrapping RG-6 around a extension cord reel (approx 8 inch circle) damage the RG-6? Just looking for a smaller and more neat way to store the wires as hooking and unhooking them from the antenna everytime is a PIA..
11 REPLIES 11
Gundog
chindog wrote:
I've used this one for years for my dish cable. No problems at all.
https://www.homedepot.com/p/HDX-150-ft-16-3-Extension-Cord-Storage-Reel-HD-130PDQ/205038360
This is what I would use I have one for my water hose works great.
2005 34' Expedition Cat C7 Allison 3000
FrankoToo
X2
FrankoToo
2018 Cruiser Stryker ST2313
2011 Ford F450 6.7L PS 4X4 Crew Cab Lariat
goducks10
I roll mine up in a 12-14" circle ending with the last 4-5' routed in and out of the circle to keep the coax from uncoiling. I have 2 small hooks screwed to the wall inside my TT storage area. I slide the top part of the coiled coax over the top hook then stretch it a little to hook on the bottom hook. It's flat against the wall and stays put taking up hardly any space.
Bill_Satellite
Fisherman wrote:
Bill.Satellite wrote:
If you go into most any store that sells coax you will find that they are bundled in about the size you are wanting to use. No problem!
Sure that's right but I would believe once the cable is sold to someone for installation it's installed permanently and not rolled up after every weekend. Kinks and bends should be avoided, that's what learned from an electronics acquaintance.
Rolling up the coax is very different than kinking or bending. Rolling up the coax will not cause any issues.
Can't we all just get along?
wa8yxm
Without doing research I think the RECOMMENDED minimum circle for Coax is 12 inches.. However I do not think 8" will damage it for that's close to how its coiled in the stores.
So Google is your friend
"The minimum bending radius is 5 times the diameter of the cable"
That's what I get for trusting memory.. 8" will be just fine.
AllegroD
No. It will not damage the cable. You will be OK, as long as you do not kink (bend) and unkink the cable.
Fisherman
chindog
2014 Fleetwood Discovery 40G
2012 Honda CRV toad
Lwiddis
โ€œ...but am looking for a better / easier / smaller way to do it.โ€
If you rolled the cable at or above the diameter in which it was sold, seems to me that would be acceptable.
Bill_Satellite
Lynnmor
Do you mean something like this?
Note that the package is just under 9" diameter in the specifications.
