โSep-09-2014 12:25 PM
โSep-13-2014 04:32 AM
dpgllg wrote:cpaulsen wrote:2oldman wrote:dpgllg wrote:1. Sat tv doesn't work with any splitters in the coax between the dish and receiver.
1.What if anything am I doing wrong?
2.How can I get this to work if I put in a second TV in our bedroom? Do I need another Dish box?
3.(cable)Under this connection would the 2nd TV in our bedroom work without any issues?
2. If you want to watch a different channel on TV 2, it'll need a separate box and coax feed
3. Yes.
I installed cable in my 5ver. From the Dish to a satellite splitter. One goes to the living room and the other to the bedroom. I use a dual tuner receiver and watch 2 different programs on the tv's. One is HD and the other is not.
OK so would this setup work for me to be able to watch Dish Network on two TV's and NOT the same channel on both?
EBAY listing
โSep-11-2014 05:59 PM
dpgllg wrote:
My questions are:
I use a satellite dish for the Dish network and can never get the wiring to work for it I have to run the cable through the window and into the dish box to get it to work.
dpgllg wrote:
Now if the campground has cable I hook up from campground post to the side of my RV and I can get a signal inside the RV.
โSep-10-2014 07:49 AM
cpaulsen wrote:One receiver? Boy, Dish must be a whole lot different from Direct.
โSep-10-2014 06:32 AM
3. Yes.
โSep-10-2014 04:25 AM
3. Yes.
โSep-09-2014 05:58 PM
โSep-09-2014 05:46 PM
the bear II wrote:
The trailer has RG6 coax Dish use RG8 coax to get the signal from the dish to the satellite box. That's why you have to run a separate feed through the window. I made mine permanent by finding a means to run the RG8 cable into the RV from the compartment my electrical cord comes out of. I was bale to feed the cable over to where the main TV and sat box sit. Now I just wind up the cable and store it inside the compartment for travel.
Some Dish Sat boxes are setup to feed two tvs. If you don't have one of those you can split the signal coming out of the box (TV out) and run a separate coax up to the other tvs or feed the TV out to your " plug on the side wear I attach the cable to for my TV signal" this will put the sat box signal onto all three TV connections...same channel will show on all 3 TVs.
If you want to see different channels on each tv you will need a dish antenna that provides multiple feeds and a sat box for each tv or "Hopper" box.
โSep-09-2014 04:56 PM
โSep-09-2014 04:21 PM
โSep-09-2014 01:39 PM
โSep-09-2014 12:45 PM
โSep-09-2014 12:39 PM
โSep-09-2014 12:37 PM
