โDec-11-2020 07:27 AM
โDec-22-2020 06:58 AM
mr. ed wrote:BobsYourUncle wrote:mr. ed wrote:
Tubes that aren't being used are impervious to extreme cold (or heat for that matter). I'm not sure about electrolytic capacitors, though. Perhaps the electrolyte substance inside could freeze at minus 30, but I can't say for sure. In time, through use, electrolytic capacitors can eventually dry out and need replacing. That jukebox sounds like it could be a valuable item. Too bad you can't store it in a warmer indoor location, but I don't think it really matters. Of course, there are mechanical devices inside (i.e., turntable motor, which shouldn't be affected, either). Any lubricating oil used on moving parts may thicken up somewhat, but return to normal when warmer temps arrive.
Thanks for that.
Didn't think the tubes would be affected, but I did wonder about the big caps.
It is a valuable item, and I was paying big bucks for heated inside storage. I was fed up with 151 bucks a month for heated storage, had to bring it home. I live in a very small townhouse and there is no room inside for it.
Since that Wurlitzer is dated from 1955, it's possible the electrolytic caps may be due for replacement anyway. But I would wait until you run it again. If the sound is good, without noticeable hum, you're probably good to go.
โDec-22-2020 05:36 AM
Thanks for that.
โDec-21-2020 05:33 AM
โDec-21-2020 05:09 AM
Since we are all reminiscing about our tube equipment days, I have a question to ask of a bunch of you who know way more than I do:
A few pages back I posted a picture of my 55 Wurlitzer jukebox. It has always been kept in a climate controlled storage location. I have only just recently, 2 weeks ago, brought it into the unheated garage at home for storage.
Alberta winters can be harsh and this jukebox will see minus 30 temperatures. I don't think it will hurt the tubes as long as I don't bump or jar them, but part of me wonders about it. There is nothing in them that will be harmed by freezing I don't think....
โDec-20-2020 11:44 AM
โDec-20-2020 10:01 AM
Learjet wrote:And then we got our Motorola Quasar TV. Solid state โwith a drawer you can pull out to replace partsโ. Well, I was just a kid but the parts werenโt replaceable but the color TV was pretty cool.
I'm old enough to remember using one of these as a kid.
Old tube tester
โDec-20-2020 09:24 AM
โDec-19-2020 01:15 PM
LScamper wrote:
The first checks done at low voltage about 10 kV. Don't remember what state things are in for the picturs (some 25 years ago). You can see two shorting hooks (JESUS sticks as someone called them in previous post) sitting on top of the amplifier. I'm sure there was hard shorts on all storage caps. When higher voltage the sides had covers on and the cables on the outside. As an aside these tubes were seasoned at 50kV plate votage for the 2.5 gigawatt amplifier string.
โDec-18-2020 10:27 AM
โDec-18-2020 06:11 AM
LScamper wrote:
In the mid 90s helped with the design of a 200 megawatt two channel amplifier. It used 12 ML8618 water cooled magnetically beamed triodes.
Some of one bank of tubes.Click For Full-Size Image.
Amplifier testing area.Click For Full-Size Image.
At one time while working on Scyllac we had an amplifier chain of 100 ML8618 tubes for a total output power of 2.5 Gigawatt. filament power was 32 kilowatt.
โDec-17-2020 01:42 PM
MrWizard wrote:
Da*!#
Don't touch the wrong place, that's not a shock
That would be instant charcoal for any warm body that came into contact with it
Phase one create insane amount of power
Phase two attempt to channel it to the target point
Phase three interpret test results
โDec-17-2020 01:34 PM
โDec-16-2020 05:07 PM
โDec-16-2020 01:40 PM
