Testing Cellular amplifiers
Maxi_Signal
If you own an android device. These are all amazing apps for testing RF signal and performance.
Open Signal, Real Signal, Signal Check Pro, Network Info II , and Network Signal INFO . These downloads are all pretty well free.
They will help you separate the pretender from the contenders
12 REPLIES 12
Dutch_12078
Great! Here's the pertinent quote for those with limited data:
"The system can cover a range of up to 53 feet providing
up to 8 users with enhanced signal strength. In our tests
we saw an increase of two bars in signal strength โ€“ the
best result so far for this type of device."
Dutch
2001 GBM Landau 34' Class A
Maxi_Signal
Just got featured in new products section of Rv Lifestyle magazine after they field tested The Max Amp Mobile RV Package. They deemed it superior to anything else they tested.
http://rvlifemag.dgtlpub.com/?i=4011
Maxi_Signal
pianotuna wrote:
Hi wa8yxm,
Does your existing device cover "band 12"?
wa8yxm wrote:
I use Network Info.. Works great.
What I need is a 4G Amplifier that works great (T-Mobile)
I know our New Amplifier covers Band 12 for sure.
pianotuna
Nomad III
Nomad III
Hi wa8yxm,
Regards, Don
Maxi_Signal
Tough call. The biggest problem is Tmobiles lack of coverage in Rural areas. But a good amplifier would help.
Bill_Satellite
Can't we all just get along?
wa8yxm
JiminDenver
Network cell info lite has a map that shows you the tower you are connected too.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
Maxi_Signal
Got another new one last week that is outstanding . Mobile Signal
Ductape
And you can read the SNR directly from the settings in Androids as well, no app needed.
49 States, 6 Provinces, 2 Territories...
Maxi_Signal
jcpainter wrote:
What's a good one to accurately tell where the nearest cell towers are for the various carriers?
Open signal will actually point out the direction of the tower
jcpainter
