Tv antenna not getting signal
hyattjlbb
Quick question. We were on cable until today and are now using our antenna for over the air channels. Switched the tv back to "air", turned the booster back on and no channels found during the scan on either of our tv's. Any ideas? I am camped outside of Madison, GA and we got about 20 channels when camped here 2.5 weeks ago. Thanks for any help/ideas!
Jamie - KE0NSE
2011 Jayco Eagle 365BHS
2019 Chevy Silverado CC SRW 3500HD, Max & Alli
Beautiful Wife of only 24 Years:B
Boy at College - 21yrs,:C
Boy - 15yrs:p
14 REPLIES 14
Adiabatman
I recently had the same problem. Found a crack in the cable just where it comes out of the bottom of the TV mast. I made up a new cable to go from there up to the head, cut the old cable and put on a new connector to connect to the new piece of cable. Problem solved.
wa8yxm
Works, then not, then works, Sounds like flakey connection
Suspects are of course primarlly the "Roof to antenna" cable.
I should have replaced my cable when I was fixing it (not sure if I did, but dont' think so) due to age.. they don't last for ever.
hyattjlbb
Well, it works now. Other than driving about 350 miles today I have no explanation. I will go back on the roof and look for corrosion, etc when we get home. Thanks for the help!
Jamie - KE0NSE
Boy - 15yrs:p
Tom_M1
Take a look at this article by Chris Bryant:
Tech- Tune up your TV antenna
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
wa8yxm
Happened to me after I cleaned the roof.. Well, started the tribble hunt.. Found no DC at the antenna.. So dig into the roof where the cable goes and found... The Problem (Corrosion had taken out the connector hidden under the clamshell cable cover.. Must have been a PPP (P*ss Pot Poor) job of caulking at factory, though it sure looked good)
Replaced connector, Replaced Cable end connector, Re-sealed using premium materails.. Watching TV as I type. Note thare are 4 Cable ends and a barrel connector plus the antenna's connector and the power supply/switch (inside device) connector. Plus fuses and wires on teh 12 volt side of the power inserter/switch.
Bill_Satellite
You would need to check to see if there is 12V power at the antenna head. Is there a light lit on the power supply (not a booster, but called that by many) when you turn it on? If not, look for a blown fuse. If there is a light, and you can get up on the roof, remove the coax from the antenna head and use a multi-meter to read the voltage inside the coax. It needs to be 12 VDC or better.
Can't we all just get along?
Old-Biscuit
Booster ON
Antenna UP
TV Input set to TV
TV Tuner set to Antenna
Antenna Head AIMED at TV Transponder Towers?
Scan for TV Channels?
Aiming Antenna
Antenna Point
DTV Reception
Antenna Web
1492
Moderator
Moderator
Moved from Forum Technical Support
hyattjlbb
Yup, antenna is up!
Jamie - KE0NSE
Boy - 15yrs:p
Mortimer_Brewst
For broadcast channels some televisions will scan for "air" stations as well as digital stations. Make sure that you have it set to receive the digital (DTV) signals.
If ethics are poor at the top, that behavior is copied down through the organization - Robert Noyce
2018 Chevy Silverado 3500 SRW Duramax
2019 Coachmen Chaparral 298RLS
rockhillmanor
Did you put the antenna back up? :W
hyattjlbb
Nope, no router or other switches.
Jamie - KE0NSE
Boy - 15yrs:p
darsben1
Do you have a switch on a router device as well?
Traveling with my best friend, my wife in a 1990 Southwind
hyattjlbb
Also checked the jumper coax and connections, to include going up on the roof to look. Still nothing.
Jamie - KE0NSE
Boy - 15yrs:p
