Waterproof Connection
hpdrver
I installed a mirror mount Sirius antenna on the top of my roof ladder. I ran the wire down the ladder and underneath my coach to the cab. I had to use a 20 ft. Extension cable to reach the cab. How can I waterproof the connection where the wires plugged together? Thanks
Texas Two Step
2021 Coach House 272XLFR
2020 JL Jeep Wrangler
11 REPLIES 11
D_E_Bishop
Bobbo wrote:
It is his link. Try:
http://www.amazon.com/Scotch-Self-Fusing-Silicone-Rubber-Electrical/dp/B0029Z5RSY
(He has an extra space at the beginning of his link.)
Boy does that take me back to the fifties. When I worked as an electrician's helper, we twisted, soldered and or wire nutted all our splices, wrapped with rubber tape and then with "Friction Tape". I remember when 3M came out with plastic tape and how much easier wrapping splices became.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
hpdrver
Thanks for the info. Used liquid tape and after it dried, I wrapped the connection with gorilla tape. BTW, if anyone is looking for a place to mount their Sirius antenna, this method was easy and nothing is blocking the antenna.
Texas Two Step
wa8yxm
I just remembered two products.. one you can often find at Dollar General, Wal*Mart and many other stores on the SEEN ON TV counter. Even Publisher's clearing house carreies it.. It is called (Among other things) Rescue tape. It is a streatchy silicon Rubber tape self sealing and works great.
The other is Antenna tape.. Now googling tghis comes up with a lot of non-hits but http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Aantenna%20tape
At least one of the products is it. Again, very much the same kind of tape. Self fusing Silicon Rubber.. Folks who have tried it said when they took the connection apart.. years later.. it still was bright and shiny as the day they hooked it up.
MrWizard
Moderator
Moderator
yep typo...sorry
I can explain it to you.
1997 F53 Bounder 36s
Bobbo
Bobbo and Lin
downtheroad
Mr. Wizzard - moderator.
Is there something wrong with your link or is it me?
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
derh20
as stated, liquid electrical tape
MrWizard
Moderator
Moderator
I have both the liquid tape and 3m self fusing silicone tape
This one is heavier, I buy it in ten foot roll at home depot about $13
The thick tape will be a more permanent solution, you will have to cut it off with a sharp knife if you ever need to get to the connection,
But absolutely nothing will get in there if you use this stuff correctly
Stretch it about 50% when wrapping the connection
No need to cover it with anything else
This is high voltage, high current, weather proof
filthy_beast
I use 3M splicing tape. You stretch it as you wrap and then cover with normal electrical tape.
Splicing tape
Goody Two Shoes and the Filthy Beast
2008 Silverado 2500HD
2012 Wildcat 282RKX
You cannot make things idiot proof, you can only make them idiot resistant.
BobKrogstie
Liquid electrical tape: http://www.homedepot.com/p/Gardner-Bender-4-fl-oz-Liquid-Electrical-Tape-Black-LTB-400/100119178
Bob and Natalie
2008 Grand Junction 37QSB
2009 Dodge 3500DRW Big Horn 4X2/CC/LB/CTD/4:10/Auto
downtheroad
Shrink tubing or maybe something like this?
Water Proof wire connector....HERE
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
