pbeverly wrote:
If you don't recognize the number, don't answer. If they don't leave a voice mail or the voice mail is questionable block the number.
Good advice.
But, sometimes answering is a must.
Businesses must answer each phone call, otherwise they go out of business ignoring potential or current customers.
DR or Medical services often use a call center that shows up as "800 Services" to relay appointments confirmation or changes to appointments.
Scammers often spoof numbers, more than once I have seen my own number calling my number so there is always a chance they will spoof a number that you know.
Scammers typically do not broadcast their own real working number, in the case of the scammer I had, they were dumb enough to use their own number.. Yeah, I called that number until they blocked mine :B Ironically I went from 30 plus scam calls a day to 4 by the next day
๐Just a warning, it doesn't always work but is has with this one and the last car warranty scammer I dealt with..
As said, best policy is often ignore, blocking has very little effect since they are generally spoofing numbers.
Many robo callers typically use AI that sound pretty darn real, generally they do not start speaking until the detect actual human voice (not answering machine recorded).. But now they have upped their game, if no non recorded voice, the call gets sent to the scammers phone and they will say something to prompt you to respond.. This gets around the call blocking that uses a 1-9 required touch tone response..
