Winngard satellite problem
Solitude010
Having a problem with winngard satillite antenna.Just keeps searching can't seem to lock on any satellites.Anyone have any ideas on how to fix?
Thank you
12 REPLIES 12
Solitude010
It turns out I have a mv3500 a dish.Amazon had a lnb that might work but I thought I would give winegard a call.Funny system leave phone number they call back.Didn't hear anything for a couple days then they called back but leave no number finally got thru to them and they couldn't be nicer even called on ssaturday and lnb on the way.They were great on email too.Let's hope it works!!!
Solitude010
Well I took off dome cover and still can't seem to find a model number.It did have lnb part number on tag next to dish but can't find that part number anywhere on web.I do have a direct tv receiver which I'm pretty sure is ok it was new last summer.I must have sk3003 as this is not hi def.
I live on an island and that's why I'm trying to fix it myself real pain trying to get it off island in the summer.Thanx for all replys
siggyd777
Try on a sunny day with blue skys,do you get anything then?
Mine worked ONLY on a sunny day,any clouds and all I got was checkerboard patterns. It was a bad (weak)LNB.
Siggy
Happy Trails
Siggy & Ursula
2011 Dutch Star 4020,ISL 400,Compr.brake,FTL XCR,IFS
Allison MH3000
2015 Jeep Cherokee,4x4 Active Drive II,V6 , Brake Buddy,Roadmaster Sterling,
Camping since 1975 Pop-Up,1986 22Ft.TT,1999 Gas MH,2005 KSDP,
2011 DSDP,FMCA 368283
Bill_Satellite
No, the Trav'ler is fully self-hosted and the antenna should lock on with no receiver, the wrong receiver or a dead receiver.
Hopefully, he will answer my questions above when he returns.
Since it is DirecTV then he either has the SK-3003 (not HD) or the SK-3005 (Slimline 5 and HD).
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
YC_1
Bill, does the travler require DC from a receiver??
If so he could check the power at the coax on the dish to be sure his coax is not open.
H/R Endeavor 2008
Ford F150 toad >Full Timers
Certified Senior Electronic Technician, Telecommunications Engineer, Telecommunications repair Service Center Owner, Original owner HR 2008
Solitude010
I have had this motor home for a couple years it always worked fine.I will have check to see which model it is .I have direct tv service. Thanks for replys
donn0128
OK, If it is a SK-3005 Trav'le dish then it is likely you have a dead LNB.
Mine did the same thing about 6 weeks ago. After a trip to the factory and now two weeks at a local dealer it is to my knowledge still DOA. Dead LNB was the first diagnosis.
Bill_Satellite
Keep the info coming here as it does not good to go off forum.
Where are you located? What messages are you seeing in the control panel while searching. If the 101 satellite cannot be located (even if others can) it will not lock on.
Does it stow after a time but the display stays lit?
Any other info you can give?
1492
Moderator
Moderator
Moved from Forum Technical Support
YC_1
Not one twig in the way???
Has it worked before?
H/R Endeavor 2008
donn0128
If this is a SK-3005 traveler, send me a PM and I will give you some information on the antenna system.
eHoefler
Need more info, is it the first time being used? What service?? Has it worked before?? With this equipment?? Etc.......
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
