โJul-22-2015 07:28 PM
โJul-30-2015 09:37 PM
โJul-29-2015 02:50 PM
โJul-27-2015 07:52 PM
โJul-27-2015 06:04 PM
โJul-27-2015 05:27 PM
pkunk wrote:
I see major speed differences between 11AC routers and 11N. Is there any advantage if I'm only going to have 30mbps? IE 1.2 Gbps over 300Mbps.
โJul-27-2015 08:16 AM
LittleBill wrote:In other words, YES.
sorry use https://www.apple.com/airport-extreme/ - https://www.apple.com/airport-extreme/
โJul-26-2015 07:42 PM
โJul-26-2015 07:52 AM
LittleBill wrote:
buy a time capsule, if you want guaranteed reliability
โJul-26-2015 06:48 AM
pkunk wrote:
Has this post gone already? I've asked several questions and get no answers.pkunk wrote:
Still looking for some insight here. Would this be a good choice or is there something better/less$$ ?
TP Link Archer
Another missing equasion-The iMac is 2009, MacBook Pro is 2010, iPhone 4, and a newer iPad Air. Compatability?
โJul-25-2015 06:52 PM
TP Link Archer
โJul-24-2015 01:56 PM
โJul-24-2015 01:32 PM
โJul-23-2015 06:35 PM
garry1p wrote:
Routers are fairly easy to set up but you do need to setup the security for the wireless I suggest WPA2-PSK.
Don't need security because no one can be in range unless they're invited
The router you buy should depend on your usage lots of wireless devices like tablets, phones and other PC's requires a higher end router.
250' is doable depending on where you place the router. Near a window on the shop side is better than trying to go through several walls.
No choice there as from where they came into the house I have about 8 ft of Cat5
โJul-23-2015 06:30 PM
