May-13-2016 01:34 PM
May-27-2016 09:42 AM
smkettner wrote:
Best you can do with the selector knob is to adjust the setting to cycle the compressor if it seems to have frozen up.
May-27-2016 07:42 AM
May-26-2016 03:01 PM
tpi wrote:
Sure if it works, it works-and yours may be set up absolutely correctly not to ice up. But be aware the conditions for ice up can be unusual. To be specific, a temperature which is relatively cool but keeps the compressor on for extended times.
Mine will rarely ice up at least partially. When looking into it the anti ice probe was installed in the wrong location on evaporator. These air conditioners, due to compact size and flow patterns do seem to run on the ragged edge of evaporator icing.
Even though yours worked, keep the tips in mind. You may need them someday under an unusual circumstance. If you do experience icing, keep fan speed on high, the filters spotless, and try to set the thermostat set to 72 or more (maybe as high as 75) to cycle the compressor before the ice forms.
May-26-2016 09:40 AM
tex wardfan wrote:If you have a wall thermostat you will have a freeze sensor. Very common for the sensor to be poorly installed. Sensor needs to be right up against the evaporator. When ice is detected it will cycle the compressor off. Very simple.
My trailer has an airxcel 48000 series roof top unit. My question is have any of you, who have this unit, had any problems with the evaporator icing up? I did not need to use the unit on our first trip but I'm sure I will have to on the next. The guy who made our trailer ready and gave us the walk through said we should always run the unit at max cool to keep it from icing up. I read the owners manual for the unit and this doesn't seem correct. It seems like that would make it ice up. Any thoughts on this would be appreciated.
May-26-2016 09:33 AM
May-26-2016 08:59 AM
May-17-2016 04:38 PM
May-17-2016 02:13 PM
May-16-2016 04:29 PM
May-16-2016 01:30 PM
May-14-2016 07:47 AM
DutchmenSport wrote:tex wardfan wrote:
...Do you always run yours on high fan speed? Even at night?
Considering (most) of our camping is in the Northern States, nights cool down and most of the time, there's no need for Air. However, come late July and August, and it can stay pretty warm at night, and then those few times, yes, we do keep the Air turned on and windows shut.
We usually keep our AC fan on high all the time, even at night (in all 3 TT we've owned.) The thermostat stays at the same spot as it was during the day. We usually set it around 75. I'm not sure what the actual temperature is in the camper, I've not monitored the actual temperature inside, we just keep it where it feels comfortable.
Thanks again Dutchmen for addressing my question as stated and not aaauming I have a problem like low Freon. I don't even know if it will freeze up, I haven't tried it yet.
At night, as the outside temperatures cool down, and the inside temperatures stay cool, the AC will cycle on-off. More off than on after a while. Even in the hottest weather. But we don't do Southern Florida, or South Texas or Arizona in the Summer either.
Whenever possible, we turn the AC off at night and open windows. If the outside temperature is cooler than the inside temperature, the AC is off and the windows open. We also have several small fans throughout our camper to keep air circulating. When the fans and / or the AC runs (especially at night), it's like a constant white noise, which actually helps lul us to sleep. And if there are noisy neighbors, it helps drown out, outside noises.
In our first and second TT, had the roof top with the controls on the AC unit, and it was a forced air, straight down model. The fan never shut off, but the compressor cycled.
In our current trailer, it's ducked with controls on the wall, the fan and the compressor both turn off and shut down at the same time. So, actually, this is a bit more annoying, in the fact it turns on and off. And when it turns on, it usually get my attention (especially at night). We could set the thermostat so it runs on fan all the time for the steady noise. But then I also can't tell how much it's actually cycling on-off. (for some reasons, I really am in-tune with my camper. I listen for sounds and am always aware of everything going on. I'm kind of strange there. I have the same problem in my house too.
I'm in tune to everything... the refrigerator when it kicks on and off, to the water softener switching on. We have an in ground (submersed) water pump in a well 50 feet deep in the ground. For some reason, I can hear the pump when it kicks on through the sounds radiating through the floor, and .... really .... even outside when standing in the yard. I can tell when water is running inside the house when I'm outside. I hear it in the ground.
So, although constant steady sounds are a great white noise, the on-off does get my attention, probably more than most people. (funny, I've been this way all my life).
So, I guess to put a simply answer to your question, once the inside of the camper reaches desired temperature, we leave the thermostat set there, even at night, fan on high. When the temperatures are cooler outside than inside, we open the windows.
May-14-2016 06:34 AM
May-14-2016 06:03 AM
Old-Biscuit wrote:DownTheAvenue wrote:Old-Biscuit wrote:
MAX COOL.....
Just means uses High Fan Speed vs Low Fan Speed
Low air flow
Dirty evap coil
Dirty return filter
High Humidity
All conditions that will cause a perfectly functioning A/C Unit to Ice Up
The #1 reason A/C units ice up is low on freon!
Let me point out something for you in my post
......cause a perfectly functioning A/C Unit to Ice Up
That and the fact that OP has a NEW RV.......isn't actually 'icing up'
but was questioning statement by RV Tech to use MAX COOL
Comprehension/reading
And YES low freon will cause icing up-------hardly a perfectly functioning unit
May-14-2016 05:20 AM
