โMay-05-2014 07:41 AM
โMay-06-2014 09:03 AM
Bumpyroad wrote:Harvey51 wrote:
What prevents water from lying in the lower half of a pipe while the air goes by in the top half? .
nothing
bumpy
โMay-06-2014 03:37 AM
โMay-05-2014 09:50 PM
โMay-05-2014 09:27 PM
โMay-05-2014 07:10 PM
Thomas/NH wrote:
I give up... If you don't want to take it from someone who does it for a living, then so be it! Over think this simple task and do it your way... You win!
โMay-05-2014 04:13 PM
โMay-05-2014 03:54 PM
โMay-05-2014 02:25 PM
โMay-05-2014 02:13 PM
โMay-05-2014 01:45 PM
Thomas/NH wrote:
There's a better way... Blow out the water, get a small air compressor, buy a special fitting that goes for the air hose chuck to a male hose thread. Start by draining the water heater (via the drain plug) then re-plug it. Drain your FW tank then run the pump dry.
Pump air into the city water connection, while building air pressure in the water heater open the faucets one at a time. Don't worry about getting every last drop out (it won't matter). Pour a gallon of the antifreeze into the traps (gray water tanks) and another into the toilet (black tank).
I winterize my rig 3-4 times a year for various trips. Being a master plumber, I winterize 10-12 homes each year (several have forced hot water heating systems). I can't be bother with trying to pump non-toxic antifreeze into the water lines, let alone the expense. This method works best for me and I hate the taste of Propylene Glycol in the morning.
โMay-05-2014 11:54 AM
โMay-05-2014 11:39 AM
CloudDriver wrote:
Winterizing kit
โMay-05-2014 08:18 AM
โMay-05-2014 07:56 AM
โMay-05-2014 07:55 AM
