May-27-2013 06:02 PM
Aug-11-2013 03:42 AM
christopherglenn wrote:All I know is I had 12V in the TT just before I connected (fridge was working)and didn't after. The converter had no output and no fuses were blown. This was the first time I had them both plugged in at the same time. Coincidence? I don't know but won't do it again.2112 wrote:Allworth wrote:I blew a converter years ago because of this. I had my F150 TV plugged in and running when I connected shore power. The DC side instantly stopped working. I have made sure not to have both plugged in ever since. New technology or proper fusing may prevent this now but I'm not going to chance it.
By the way, I don't like to have shore power and truck power hooked up at the same time. I don't think it can hurt anything, but I would rather not mix electrical systems. Particularly complex ones.
I doubt that was the cause, with my truck running I am showing 14 volts on the truck batteries - and 13.2-13.5 on the trailer batteries. The set point on my original converter was 13.7, my inverter-charger is 14. There is so much resistance between the truck and trailer batteries that .5+ volt difference (when running / charging) is normal. And yes, the charge line works, there is a voltage drop when I hit the remote start from the trailer, followed by a slight voltage climb a few seconds later.
Aug-10-2013 09:40 AM
Aug-10-2013 03:26 AM
Aug-10-2013 03:04 AM
Aug-09-2013 10:34 AM
Aug-09-2013 10:30 AM
Aug-09-2013 04:17 AM
Aug-09-2013 02:26 AM
Terryallan wrote:
Yes on Fords, the batteries are only connected when the switch is in the on position. And yes. If you have the towing package relay installed on your Ford. It in fact charges the trailer battery as you drive down the road.
May-29-2013 08:27 AM
May-28-2013 06:15 PM
May-28-2013 06:14 PM
May-28-2013 09:19 AM
ScottG wrote:
On your FOrd it is indeed separate and they are only connected together when the key is on.
Dodge and GM are always connected together.
FWIW, I've had it both ways and I actually prefer them to be tied together.
May-28-2013 07:37 AM
May-27-2013 07:29 PM
